Announcements
Installer not working
Downloaded AutoCAD for Mac, and it worked fine for a while then started freezing during startup. Uninstalled and reinstalled, and it continued to work for some time before the initial problem reoccured. I tried to uninstall and reinstall again, but now am getting an error message that says the installation failed and to contact the software manufacturer. Found a page in the troubleshooting tips about what to do with this pop up, but none of them helped.
maxim_k
Welcome to Autodesk Forums!
Hi Carol,
Your AutoCAD version is ....
macOS version installed on your Mac is....
Please provide more information.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hello Maxim,
Thanks!
AutoCAD for Mac 2020
OS 10.15.3
maxim_k
Can you share install.log file from your Mac?
You can find it inside /var/log folder.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I looked, but couldn't find the file
maxim_k
It should be there.
In Finder use menu Go -> Go to Folder...
Copy - paste:
/var/log
pick on Go button.
Look for install.log file there.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
