Installer Files - AutoCAD 2012 x64bit
Good day,
I am working in an environment where the company uses AutoCAD 2012 x86. Previously, their environment was running on Windows 7 x86 so there were no issues with using the x86 installer, but they have recently begun testing Windows 7 x64 bit for performance reasons.  It looks like they only have downloaded the installer files for the x86 version of the software.  I have read through a few posts on some fixes for the issue, but was wondering if it was possible to get the x64bit version of the software?  I am trying to avoid having to use 3rd party applications or the Win XP virtual environment to run the software.
I checked the Virtual Help portal and it looks like they currently have products only as far back as 2013.  Is there anywhere within the Autodesk support site that I can obtain a copy of AutoCAD 2012 x64bit?  I also thought I would mention that we are running a single server licensing solution for the application as well.
Any thoughts or comments on how to obtain the installer would be much appreciated.
Best regards,
-Steven
ukdxb012
when i installing that time asking use 64bit installer......sir how can i install the cad on my system?
Mark.Lancaster
@Anonymous
Welcome to the community...
Are you looking to install AutoCAD 2012 as well or something else?  If your request/issue has nothing to do with AutoCAD 2012, then create you own posting and describe exactly what issue you are faced with.  You have provided a limited amount of information and we are unable to assist or point you in the right direction at this time.
Mark Lancaster
