Installation Problems for Autocad 2017 Student Version
Message 1 of 14
Hi, I am a student and am having problems installing Autocad 2017 Student version.  The error I get when i go to install it is that it cannot find the setup.exe file.  I am installing on windows 10 surface book.
Replies (13)
Message 2 of 14
Otto
Hello prh13 and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 14
thank you!
Message 4 of 14
Mark.Lancaster
@Anonymous
Welcome to the community
How are you installing the software?  Using the install now option through your educational account?
Mark Lancaster
Message 5 of 14
yes, and thank you!
Message 6 of 14
Mark.Lancaster
Just use this method
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
Message 7 of 14
Thanks Mark, you helped so much!
Message 8 of 14
Mark,
I don't know what is wrong, I attached a picture of the error window that popped up.
Peter
Message 9 of 14
Mark.Lancaster
@Anonymous
You accepted my reply as a solution but you failed to follow any of those steps.  Smiley Wink
If you are seeing anything related to the download manager then you are using the wrong method.   The virtual agent has nothing to do with the download manager so I know for a fact you are not using the correct method or the steps I provided.
Follow my steps and you should be able to install your product.
Mark Lancaster
Message 10 of 14
I followed each step above again and got the same results. The cursor hovered above the files that downloaded are shown in the screenshot I attached and it is related to the Autodesk Download Manager.
I have spent the last hour trying to figure out how to do this and reading about it and haven't had much luck.  I am not much of a computer guy but I know I followed your steps.
I want to clarify also that I am not trying to argue with you, I'm just trying to figure out this problem to get a solution.
Thanks again
Message 11 of 14
I am still trying to download these programs for my classes and having no luck.
Message 12 of 14
Mark.Lancaster
If you downloaded the part or parts from Autodesk Virtual Agent you should see (assuming its the English version) these files in your download folder.
32b Windows Operating System
AutoCAD_2017_English_Win_32bit_dlm.sfx.exe (1.7 GB)
64b Windows Operating System
AutoCAD_2017_English_Win_64bit_dim_001_002.sfx.exe (2 GB)
AutoCAD_2017_English_Win_64bit_dim_002_002.sfx.exe (281 MB)
If you do are the files the correct size as I indicated?
If everything looks good, when you double click on the first file listed for your operating system it should start the extraction and prompt you to extract to C:\Autodesk.  It does take a second or so before the extraction location message to pop up.
Mark Lancaster
Message 13 of 14
Thanks Mark, sorry for the trouble.  I had to do some reading and decided to retry using the download manager which ended up working for me.  I appreciate everything. (:
Peter
Message 14 of 14
Mark.Lancaster
@Anonymous
No problem glad to help and glad to hear its working now for you...
I also have to say that I didn't realize the extraction method of files coming from the Virtual Agent still used the Download Manager service/interface.   Learn something new today..
Yesterday was a busy day for me and when I quickly looked at your image and saw the Download Manager message I just assumed you were using the wrong method thus my reply.  So sorry about that since it was incorrect Smiley Sad (and you were actually following the steps)..
Mark Lancaster
