Installation freezes on Microsoft Visual C++ 2017
s252499
s252499
Hello.
I have been attempting to install AutoCAD Architecture 2019 and 2020 to my PC.
However, every time the installation freezes when at Microsoft Visual C++ 2017 installation process. The installation bar is active, but overall progress does not go and stops on 27/30 or 28/30.
I was trying to wait for 30 mins, 1 hour, 3 hours, but nothing has happened.
What I did:
- reinstalled Microsoft Visual C++ from 2015 to 2019, including 2017
- completely removed MS Visual C++ 15, 17, 19
- completely deleted all files related to Autocad previous versions, including those in AppData
- put my lop bunny on the keyboard hoping he could do some magic
Nothing helped.
So I am a bit desperate, since I can't even find a solution to this problem in the web.
My PC specs:
MSI Ge70PL Apache
Windows 8.1 64 bit
I would be extremely grateful if someone gives an idea of how to deal with this. Even my bunny is desperate.
Screenshot of installation window attached.
May
Mark.Lancaster
@s252499
Without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
m_latz
From Microsoft Visual C++ 2015 till Microsoft Visual C++ 2019 you can have only the newest version.
So if you have successfully installed "Microsoft Visual C++ 2019", remove 2015 and 2017 from the setup.ini and try again. It is possible, that the older runtime installer have problems if the newest Visual C++ 2019 runtime is installed.
regards
Markus
