公告
Install Error 1603
Install Error 1603
david_quist
3,941 次查看
7 条回复
1 条消息(共 8 条)
Install Error 1603
david_quist
Good afternoon,
Last Friday my computer had a major failure. After it was fixed, we installed AutoCad Mechanical 2025. We ran into the Add-in programe we use currently does not work with 2025. We attempted to install 2024 but got an error during the install. "Install Failed - Error 1603. Fatal error during install". We uninstalled 2025 hoping we could then load 2024. It did not work. We uninstalled the Add-in. Rebooted the computer and tried again. Again, the same error pops up. We currently are stuck.
Any advice on how to fix this?
0 个赞
已接受的解答 (1)
3,942 次查看
7 条回复
回复 (7)
2 条消息(共 8 条)
pendean
Community Legend
Community Legend
Which of the dozen Autodesk / Vendors links addressing this exact error 1603 in a websearch have you done so far please?
0 个赞
3 条消息(共 8 条)
handjonathan
Hi @david_quist
Thanks a lot for posting your question to the forums!  There could be several causes a,s listed below.
  • Autodesk Desktop Licensing Service is not running or not running properly due to permissions.
  • Windows Installer issue.
  • Visual C++ redistributable is corrupt.
  • Microsoft .Net framework failed to install or was corrupted.
  • Corrupted installation of the program.
  • Corrupted installation of a product update.
  • Corrupted residual component installed.
  • Autodesk Desktop Licensing Service is set to run as "This account" in Windows Services.
  • Conflict with security software.
Solution:
Follow one or more of the following solutions to solve the issue:
Update the Autodesk Desktop Licensing Service and the Autodesk Identity Component.
  1. Download and install the latest update for:
  2. Try again to start your product.
Uninstall and Reinstall the Autodesk Desktop Licensing Service
  1. Uninstall Autodesk Desktop Licensing Service.
  2. Download and install the latest Autodesk Desktop Licensing Service.
Restart or check if the Autodesk Desktop Licensing Service is running
See How to check the status of Autodesk Desktop Licensing Service
Uninstall and reinstall AdODIS
  1. Go to C:\Program Files\Autodesk\AdODIS\V1.
  2. Right-click RemoveODIS.exe and select "Run as Administrator".
  3. Download the latest version of ODIS.
  4. Run AdODIS-installer.exe.
Uninstall and reinstall Microsoft Visual C++ Redistributable
See How to remove and reinstall Microsoft Visual C++ Redistributables packages
Security software conflict
Configuring the settings of, disabling, or uninstalling security software may be required. Refer to: Autodesk Licensing Service: Known Conflicting Applications.
Remove previous corrupted installation
  • Remove with Microsoft Troubleshooter (also known as Fix-It) old residual leftover installation for the software that you are trying to install.
  • Check the Registry for any potential leftover installation for the software you are trying to install and remove it manually (Note. Be careful with the Windows Registry. If you are not an expert, ask your Admin to perform this step!).
Clean uninstall and reinstall
  1. Perform a Clean Uninstall, see How to perform a Clean Uninstall of Autodesk products on Windows.
  2. Reinstall the product.
See Also:
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
0 个赞
4 条消息(共 8 条)
david_quist
已接受的解答
Thankyou for your helping. It had been decided that the install somehow was corrupt, or had been corrupted somehow. As this PC had just been fixed, new board and hard dive, It was easy to run it back to before the attempt. After doing that, AutoCAD 2024 loaded and is working well now.
I appreciated the replies. Thank you very much.
Have a great day.
5 条消息(共 8 条)
AutodeskCommunityUser
Non-Worked! Am I missing something it use to be so easy to download your software. It was just a push button, now you have to be a computer scientist. 😂
0 个赞
6 条消息(共 8 条)
pendean
Community Legend
Community Legend
What did you try? What exactly did not work?
What is your exact error message?
What is your OS version?
Which software are you trying to install?
0 个赞
7 条消息(共 8 条)
david_quist
Something happened during the down load of 2025 that would not allow 2024 to also be downloaded. had decided to just go with 2025 until an add-on program wouldn't work with 2025. They said they are working on it. When I tried to go back to 2024 it would not install in. It kept crashing. As this PC was just repaired from that cloud strike thing, our IT decided to just start over. there wasn't anything to lose. That worked well. I am back on 2024 and will update to 2025 when the add-on program is also updated to 2025.
0 个赞
8 条消息(共 8 条)
I appreciate the information. What it came down to for me was, I had to call Autodesk for assistance. I then Gave them access to my computer. They literally had to repair the core 🙄
0 个赞
