install autocad 2018
Message 1 of 9
I tryed to install autocad 2018, but it couldn't install Autodesk and so on. So now I can use Autocad but not the other components...by the way, I tryed to unistall autocad, but apparently I can't do it. .
Replies (8)
Message 2 of 9
Otto
Hello cler.92 and welcome to the Autodesk community!
We see you are looking to uninstall you program. Other users have found the following processes helpful to perform a complete uninstall.
  1. Autodesk Uninstall Tool
  2. Conduct a Clean Uninstall & MSfixitTool to complete the uninstall
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 9
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the screenshot. The error message in the small box (from first screenshot) wasn't clear enough. Would you mind to provide another one so that we can read the error message better?
Besides, are you using commercial license or student license?
AmandaWong
Autodesk Customer Support
Message 4 of 9
This is checklist before installing AutoCAD and Other components.
1. Turn off Anti-virus, firewall
2. Make sure connection Internet
3. It needs at least 6GB on your disk space
4. Verify that the installation path is correct (C:\Program Files\Autodesk\Your Version)
5. Clear your Temp folder (Link)
6. Disable UAC (Link)
Message 5 of 9
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just to follow up. How is your AutoCAD doing at the moment? Is the error still showing?
AmandaWong
Message 6 of 9
(Sorry for my absence, I had troubles with internet connessione) actually I read all the comments now, so I’ll try to follow them...but until now I have found no solution...
Message 7 of 9
Btw I’m using a student license. And the error message come up because I’m trying to uninstall the program but apparently I cannot Because, as the error message says “an installation for FARO LS 1.1.6006 (64 bit) is currently suspended. You must undo the changes made by installation to continue. Do you want to undo those changes?” And even I click “yes” it keeps on ask me this. And what is faro?
Message 8 of 9
jeffrey.sin
Hi @Anonymous,
Are you also unable to uninstall even if you use the Microsoft FixIt Tool? Try using that to uninstall the software then follow the recommendations in the previous responses before reinstalling.
If issue persists, try following the suggested solution here. Let us know how it goes. Thanks.
Jeffrey Sin
Message 9 of 9
jeffrey.sin
Hi @Anonymous,
Have you already had the chance to try out the suggestions above to uninstall your AutoCAD software? Let us know if you are still having issues with it.
Jeffrey Sin
