How to update Autodesk related products update if C:\Autodesk\Autodesk_%productname% folder can't be found?
soonhui
Advisor Advisor
soonhui
I understand that C:\Autodesk\* stores installation related files, and is useful if one wants to perform update of the software.
The problem is that in my case here ( Civil3D 2022, but I guess the same principle applies to AutoCAD 2022), the related installation folder at C:\Autodesk\Autodesk_Civil_3D_2022_English_Win_64bit_wi_en-us is missing; I thought I store it at backup location, but I couldn't find it ( older versions of Civil3D installation folder are there, so this is not a simple case of I forgetting exactly where the backup location is). If I could find it I can put it back to C:\Autodesk\* to perform a Civil3D 2022 update.
Now I can't perform the update; because the Autodesk Desktop app will crash when I try to launch it. I suspect that it's because the relevant files at C:\Autodesk\* is not found.
How to update Autodesk related products update in my case here?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
Valentin_CAD
@soonhui ,
Check these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
soonhui
In the end I just
  1. Uninstall Civil3D 2022
  2. Redownload and reinstall it
  3. And then only use Autodesk App tool to update it to 2022.1
Ngu Soon Hui
Valentin_CAD
@soonhui ,
Glad one of the suggestion on the links worked.
Emilio Valentin
