How to silently uninstall DWG TrueView 2022?
Message 1 of 11
Trying to silently uninstall software  fails if using the information in the registry:
[Execute-Process] :: Executing [C:\WINDOWS\System32\msiexec.exe /x "{D7A6621A-1A6A-3DAC-BBD2-9EB566035195}" REBOOT=ReallySuppress /QN]...
[Uninstallation] [Execute-Process] :: Execution failed with exit code [1605] because the product is not currently installed.
This article is not updated for version 2022
How to deploy and uninstall DWG TrueView via command line or via SCCM | DWG TrueView | Autodesk Know...
/Lars-Olov
Replies (10)
Message 2 of 11
Hi
I found it {28B89EEF-5128-0409-0100-CF3F3A09B77D} It will remove DWG TrueView 2022 but it will still keep the "uninstall app" as it will still show in Add/Remove Programs list......
Message 3 of 11
I have solved it by installing the msi files instead.
3rdparty:
\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe  /install /quiet /norestart
\3rdParty\x64\VCRedist\2019\vcredist_x64.exe /install /quiet /norestart
trueview:
\x64\dwgviewr\dwgviewr.msi ADSK_SETUP_EXE=1 ADSK_DESKTOPSHORTCUT_1=0 REBOOT=ReallySuppress /QN
Message 4 of 11
mrogalski
@Anonymous  I was able to successfully install DWG TreuView with your commands, thanks!
For uninstall I ran msiexec.exe /x {28B89EEF-5128-0409-0100-CF3F3A09B77D} /quiet per the official Autodesk documentation and it did uninstall the software however it killed explorer.exe and I was unable to script restarting explorere.exe so I dug around and found adding:  MSIRESTARTMANAGERCONTROL=Disable /quiet stopped the problem.
So my final uninstall command is:
msiexec.exe /x {28B89EEF-5128-0409-0100-CF3F3A09B77D} MSIRESTARTMANAGERCONTROL=Disable /quiet
It also works with uninstalling DWG Trueview 2018 which is the version we are updating from.
Message 5 of 11
I have done silent install of Autodesk Trueview 2022 "Setup.exe --silent" as per the doc.
during uninstall via product code i could still see entry in ARP.
would appreciate if anyone can give me switch to Uninstall the application.
Message 6 of 11
jorgosz.bacsosz
I have same issue. Please, give a solution for the full silent uninstall. Thanks.
Message 7 of 11
This doesn't seem to remove the whole program? I still see Autodesk DWG TrueView 2022 in Settings > Apps & Features.
Message 8 of 11
Jason Bergner at silentinstallhq.com has a how-to guide available for TrueView 2022. Bless him.
I can confirm the following works. Including the uninstall command which does remove the entire application, unlike the msiexec.exe command posted above.
Install: Setup.exe -q
Uninstall: "%ProgramFiles%\Autodesk\AdODIS\V1\Installer.exe" -i uninstall -q -m C:\ProgramData\Autodesk\ODIS\metadata\{D7A6621A-1A6A-3DAC-BBD2-9EB566035195}\bundleManifest.xml
Message 9 of 11
The main problem is that new installation through ODIS instead MSI create a product code DIFFERENT for each machine where program is installed.
If you search in registry where you have installed the program you'll find an uninstall string like this
C:\Program Files\Autodesk\AdODIS\V1\Installer.exe -i uninstall --trigger_point system -m C:\ProgramData\Autodesk\ODIS\metadata\{087B95DF-F444-3F18-B633-4A7A0A0488A4}\bundleManifest.xml -x C:\ProgramData\Autodesk\ODIS\metadata\{087B95DF-F444-3F18-B633-4A7A0A0488A4}\SetupRes\manifest.xsd
Due this string is different on each computer in such scenario is not possible to uninstall silently.
Message 10 of 11
MattDeMeo
Trueview 2023: Change the number and it worked on Freedom.
"C:\Program Files\Autodesk\AdODIS\V1\Installer.exe" -i uninstall -q -m "C:\ProgramData\Autodesk\ODIS\metadata\{7ACB914A-304E-3C03-88C6-7C75E6B16EB8}\bundleManifest.xml"
 Installer Files to look at - DWG TrueView 2023 - English - (EN)\setup.xml" fot this line:
<UPI2>{7ACB914A-304E-3C03-88C6-7C75E6B16EB8}</UPI2>
Trueview 2023. Find the Installer in \metadata to verify you have the correct number. {7ACB914A-304E-3C03-88C6-7C75E6B16EB8}
Message 11 of 11
jorma_heikkuri
Please check Windows registry.  Here are some different DWG TrueView 2023 - English versions. Latest and final is the 2023 Update 1.5.
With ODIS the installation / uninstallation works a bit differently compared good the old time.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E658D379-EEC7-38FD-928F-9344028EDA52}
DisplayName = Autodesk DWG TrueView 2023 - English
DisplayVersion = 24.2.181.0  => 2023 Update 1.4 = T.181.0.0
This was some "test version" before real 2023 Update 1.5
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91443368-3E7B-4B5D-8A8E-7DA489BC7318}
DisplayVersion = 24.2.192.0 => 2023 Update 1.5 = T.192.0.0
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C57950C4-2BF1-3035-9257-7B8F746DADD8}
UninstallString = Yes it's extremely long string.
I disagree : Due this string is different on each computer in such scenario is not possible to uninstall silently.
You must always use the ODIS code!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Which-silent-comma...
