Fusion360 wont load after attempting a reinstall because it crashed on launching
Message 1 of 12
Fusion360 lauched but crashed after approx 10 seconds. Did a clean uninstall, and tried to reinstall a clean copy but failed due to the error as per attached.
Thanks for any help
Replies (11)
Message 2 of 12
leowarren34
Have you tried running as administrator?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 12
Hi. Thanks for your interest.
YES, tried running as administrator. - still did not work.
Read online to do a clean uninstall, but when I tried to reinstall, Fusion360 quits with the attached error (Win error 740)
I have no idea how to fix / repair this error so I can resume using Fusion360. (NB. I am retired and trying to teach myself CAM.
Regards
Bernard Lewis (New Zealand)
Message 4 of 12
leowarren34
Hmm..
Administrator should bypass that, are you the only user of the PC and what is user account control set as that can interfere with high level programs. User account control can be found in control panel.
Leo Warren
Message 5 of 12
Yes, only user with administrator setting. One other unused user account with "user settings" See account controls attached.
Message 6 of 12
Have a look at this article:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Win...
It covers what @leowarren34 already mentioned but gives a bit more detail.
In addition, the log file you posted seems to indicate you were streaming the install over the Internet - not sure if it's different for Fusion 360 but usually you can choose an alternative method of Browser Download in your Autodesk account. This downloads the installer to your PC which you can then run as administrator, maybe this will help.
Note: When you uninstall, make sure you're following the Clean Uninstall guidance from Autodesk: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Message 7 of 12
leowarren34
Try these download methods:
https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods
Leo Warren
Message 8 of 12
Hi Still no luck re-loading Fusion360.
Same win740 error.
Floowed the instructions but to no avail.
Log file attached
Regards
Bernard Lewis
Message 9 of 12
leowarren34
Some further research suggests creating a new admin account with full access and UAC disabled, then install and run as administrator, it also suggests scanning the registry as any errors can cause problems. Thirdly the error log seems to be trying to remove a file that doesnt exist.
Leo Warren
Message 10 of 12
Hi.
Yes, separate login as administrator has worked. However as clean uninstall was done, I have lost my tool library.
Regards
Bernard Lewis
Message 11 of 12
leowarren34
Atleast its progress, what tools are you missing?
Leo Warren
Message 12 of 12
Just my local tool library. Not a major.
I have only a few tool holders so have to keep changing anyway.
Of greater concern is why Fusion stopped working in the first place. My PC
is pretty much dedicated to my cam.
Thanks again
