Flex user here. Revit 2027 installed, but no link anywhere to the Viewer mode...
balazs_trojak
balazs_trojak
Will it charge a day's worth (10 tokens) just to complete the installation at first run?
vladimir_michl
No, if you just start Revit (or any other app) once and then close it immediately (in minutes), Flex tokens are not charged.
Vladimir Michl,  www.arkance.world - www.cadforum.cz
balazs_trojak
Thank you, I ran it full for two minutes then closed, but the viewer has not appeared.  Where is the viewer mode for 2027?  I now replicated the viewer shortcut (copied the shortcut from a previous version) to read "C:\Program Files\Autodesk\Revit 2027\Revit.exe" /viewer /language ENG but it just opened in full mode, not viewer.
balazs_trojak
I've ran this command from the command line "C:\Program Files\Autodesk\Revit 2027\Revit.exe" /viewer and it still opened in full mode.  Now it has taken 10 tokens as well.  3 times opened for less than a minute each within 10 minutes and boom.  Terrible really.
Thanos603
Viewer mode was removed from the 2027 release of Revit.  For more details, please refer to https://help.autodesk.com/view/RVT/2027/ENU/?guid=GUID-2D1C3667-B5F0-4243-B050-DBD9D7CFAC65.
Anthony Michniewicz
Principal QA Analyst
balazs_trojak
Despicable.  Shame on you Autodesk.
pendean
Community Legend
Community Legend
This has always worked, still does, and no tokens are used either
https://viewer.autodesk.com/designviews
