Error while trying to activate autocad 2021
b_huertacrdova
Observer Observer
Message 1 of 26
b_huertacrdova
Observer
Observer
I am trying to activate autocad 2021 with a license that I have purchased but when I try to activate it it gives me the following error "This content cannot be displayed in a frame", after that it does not let me do anything and when I close the window it also closes the autocad window
The error persists on several computers and nothing I have done has worked, I have tried reinstalling Windows, updating drivers, the Autodesk license manager, I have also tried using another internet connection in case my ISP was blocking some Autodesk service but nothing worksimage (6).png
Replies (25)
Message 2 of 26
tfernandes2
Community Visitor
Community Visitor
I'm having the same issue with Autocad 2024, contacted support but they didn't help.
Message 3 of 26
wispoxy
  1. Check your firewall settings.
  2. Make sure you're using a licensed version of AutoCAD.
  3. Make sure you have a network connection.
  4. Global Use Rights Approved Country List, make sure you're listed.
  5. Proxy servers or VPN can cause issues.
  6. Reinstall but flush all cache data and appdata.
Message 4 of 26
Simon_Weel
See this: Error "This content cannot be displayed in a frame" after entering the serial number - Autodesk Comm...
I did some searching and it seems the error is thrown by Internet Explorer. Internet Explorer has been deprecated for a while and should be disabled for Windows 10 and 11. There's still the IE-mode you can use in Edge, but you have to bent over to get it working.
Anyway, check if Internet Explorer is still around?
Edit: Can you click / select the window and then press F12 to show what's under water?
Message 5 of 26
jenrix.kot
I have the same error for three days, I do not know what to do(
Message 6 of 26
jenrix.kot
During this time, I found some explanation for the problem.
The problem is that after a clean install on a computer that did not have Autodesk products on it before, there is no specific set of cookies when the window opens. Therefore, the server does not accept the request. If you install a new product on a computer that previously had an activation system, it will work. But if you clear cookies in Internet Exlorer, this problem occurs and you will no longer be able to use the activation system.
Message 7 of 26
Simon_Weel
BTW - activating using a serial number is out of fashion - but I'm not sure as of which version....
Message 8 of 26
jenrix.kot
It is active even in the 2025 version there is a button to activate with a serial number, they give it to educational institutions as far as I know
Message 9 of 26
b_huertacrdova
Observer
Observer
this is all i could get from the pop up f12 didn't work
Message 10 of 26
mdavis22569
Can you try reinstalling Google Chrome .. and and Edge:
https://www.microsoft.com/en-us/edge?ep=379&es=79&dlb=M022&form=MM1476&ef_id=_k_Cj0KCQjwztOwBhD7ARIs...
Please then reboot and make sure all of the Windows updates and app's updates are installed.
Make sure you don't have a firewall on and try starting the software.
Mike Davis
Message 11 of 26
Simon_Weel
Also try the latest license service: Autodesk Licensing Service download
Message 12 of 26
StevenFisher
Community Visitor
Community Visitor
I'm having trouble using running the license transfer utility to export an AutoCAD 2021 perpetual license.  Same error screen as in original post when trying to enter Sign-In credentials.  I downloaded AdskLicensingInstaller-win-14.1.0.10619.zip, ran the installer and it created the folder  C:\Program Files (x86)\Common Files\Autodesk Shared\Adlm\R30.  The R30 folder does not have the LTU.exe executable.  If I run from the shortcut in the Windows Start menu, it still runs the old non-working utility from the R20 folder.  Where/how to get an updated LTU.exe?
Message 13 of 26
robert_suun
Community Visitor
Community Visitor
I have the same problem. Reinstalled everything, even tried other computers on other networks. The issue is with autodesk.
Message 14 of 26
lab_costruzioniUHKPK
Observer
Observer
I have an educational license and 20 new workstations with autocad 2025, none of these  can activate the license because the frame is opened in old explorer browser not in edge or chrome. How can I solve?
Message 15 of 26
salesVWEGW
Community Visitor
Community Visitor
Also having issues
Message 16 of 26
malshehhiXSVSU
Observer
Observer
same issue. Anyone came up with a solution?
Message 17 of 26
jmperez6HHRU
Community Visitor
Community Visitor
Message 18 of 26
jmperez6HHRU
Community Visitor
Community Visitor
Same issue with Revit 2023 here for me as well. I was able to activate half of my schools lab computers until a few days ago then all of a sudden the remaining computers can no longer access the auto desk sign in page with the same error. tried using a wireless hotspot to make sure it was not an issue with our districts firewall but the issue did not improve. The instructions provided by Project Lead The Way insist that we use serial based activations for our education institutions.
Message 19 of 26
DarrenP
this is known issue
no fix or workaround
another post on this: https://forums.autodesk.com/t5/education-installation-licensing/add-license-key-after-a-trial-fail-e...
DarrenP
Message 20 of 26
jmperez6HHRU
Community Visitor
Community Visitor
Ok, thank you for the quick reply and for the new insight. Much appreciated. Glad to know the team is aware and working on it.
