Error on Start - Vault Professional Client 2023
karthur1
Mentor Mentor
Message 1 of 20
karthur1
I installed Vault Pro Client 2023.  Right after the log-in screen comes up, I get the dialog below. After this, the only thing I can do is kill the process with windows task manager.  I have uninstalled/reinstalled twice but still get the same results.  I have also tried cleaning out the C:\temp folder before I reinstalled.
I have also tried to run as admin, but that did not help.
Any clues how to get this install and run.
Kirk
P.S. I do have Vault Pro Client 2022 installed and it runs great.  Just trying to test 2023 Vault Pro.
Replies (19)
Message 2 of 20
mdavis22569
Firewall / anti-virus access allowed?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
Also check out:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Mike Davis
Message 3 of 20
karthur1
That's not good !!!
Inventor / ACAD / Vault Pro 2020 (and 2022) were working great before I installed Vault Pro 2023.  It all went downhill after that.  Now when I run Inventor 2020 and go to the "Manage License" page, I get this.  Again, in order to get past this, I have to use Windows TS and kill the process.
Message 4 of 20
mdavis22569
recent Windows update?
What happens if you unplug from the network / wifi / internet and start them?
Mike Davis
Message 5 of 20
karthur1
Inventor will launch with it un-plugged, but I still get the same blank dialog when I go to "Manage License".  Here is a list of recent Windows updates.  One of these might have broke things.  I don't access the "Manage License" very often, so not sure when it got into this shape.
I am assuming installing the Vault Pro 2023 did it though. I did install Inventor 2023 first, then Vault Pro 2023, so not real sure.
Message 6 of 20
mdavis22569
What version of Autodesk Licensing services are you on currently?
Mike Davis
Message 7 of 20
karthur1
I just updated the ADSSO Component to V13.7.7 and the Autodesk Licensing Service to V13.0.0.8122.  Did not fix the issue.
I also ran across this page that discusses the blank image when accessing the license type.  Working thru that now.
Message 8 of 20
mdavis22569
Need be reset the licensing via this:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Mike Davis
Message 9 of 20
karthur1
I'll take a look at that tomorrow.  I also found this article that describes how to reset the licensing for 2023 products.  Travis even has a .cmd script to help with resetting it.  It seems like the LGS.Data is what is hosed.
Message 10 of 20
karthur1
The "blank" or White image when accessing the license type is also there in my Vault Pro 2020, Autocad 2020 and Inventor 2020.  Since Vault Pro is the easiest/quickest to uninstall/reinstall, I did that.  After the reinstall and reboot, the issue still persists.
The "Reset_login_win" from Autodesk did not help.
Message 11 of 20
mdavis22569
Did I share the URL's for access?
Possible something minor is getting blocked
Mike Davis
Message 12 of 20
karthur1
I don't think so.
Message 13 of 20
mdavis22569
Only other option I have ...  try a different profile
Mike Davis
Message 14 of 20
karthur1
@mdavis22569
When I said "I don't think so".  I was answering your question about sharing the url's.  I agree with you that something probably getting blocked.
I am wanting to try a different profile, but will have to wait on my IT guy for that.
Message 15 of 20
karthur1
I just had my IT guy log-in with his windows account and it the "Manage License" works as expected.  He "rebuilt" my windows account and now when I log-in with my account and go to "Manage License", the problem still persists.
Not sure.  I will open a support case with AD.
Message 16 of 20
mdavis22569
Can they make you a temp profile and test?
If they can do it, then it's something for you
Is it assigned to you?
Mike Davis
Message 17 of 20
karthur1
I am still trying to get this resolved.  I tried to reset the license via your post #8 above.  Didn't change anything.
I found this article on "How to Change the License type for an already installed product".  I ran this CMD command and used the "-lm USER" option which should set it to a named user account.
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change -pk 569N1 -pv 2022.0.0.F -lm USER
Now when I start Vault Pro 2022, I get this.
I can change it back to a network account by using this command.
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change -pk 569N1 -pv 2022.0.0.F -lm NETWORK
Now when I start VP 2022, it starts normally, but its using the network license.
A few noteable things:
1. The Vault Pro asset is assigned to me (I am our account admin).
2. I have a support case for this (# 19884968), but we have not gotten very far with it.
3. The support tech had me run the "ADSK Licensing Support Tool".  It found two inaccessible URL's, but I ran it on another system that does not have this issue and found the same two inaccessible URL's.
4. I cannot create a "test" user account.  Our Windows accounts are managed by an outside IT company.
5. I did try logging into another workstation here using my Windows credentials.  When I start Vault Pro 2020 and try to "Manage License" I get the blank white dialog. as in message #3 above.
Kirk
Message 18 of 20
mdavis22569
@ihayesjr or @CGBenner  can you help an EE out on this?
Mike Davis
Message 19 of 20
ihayesjr
I see that you are already working with a license support team member through your case. After reading this thread, I see that you have tried many of the things I would have recommended.
The last thing I could tell you to try is resetting the license so that it prompts you to pick a license type instead of setting a license type through the command line.
See the Reset LGS section in this article. Autodesk Licensing Installer Helper tool guide | AutoCAD 2022 | Autodesk Knowledge Network
Make sure you delete the local license cache first.
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change -pk 569N1 -pv 2022.0.0.F -lm ""
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 20 of 20
karthur1
Irvin,
 Tried to Reset the LGS (first deleted the license cache). Now when I start VP 2022, it goes straight to the "ipmErrorText" dialog as before, which should be where I select the license type.
