ERROR MESSAGE: "LICENSE MANAGER IS NOT FUNCTIONING OR IS IMPROPERLY INSTALLED."
Message 1 of 31
Program does not launch, i get error message: "License Manager is not functioning or is improperly installed. Autocad will shut down now". I download hotfix and installed, same result.  Went to support page and went down the list of suggested solutions, same result. Tried contacting tech support but they are booked for days.  NEED HELP PLEASE!!!!!
Replies (30)
Message 21 of 31
Autocad LT 2020.
Windows 10.
What do you mean "is it there and started?" It's on and functioning and has
been fine forever until now.
Message 22 of 31
Mark.Lancaster
@Anonymous
Can you stop that given service and reboot your machine.   Does the service start back up?
Mark Lancaster
Message 23 of 31
Yes.
Message 24 of 31
Mark.Lancaster
@Anonymous
Go here C:\Users\<user name>\AppData\Local\Autodesk\Web Services and delete the loginstate.xml file
Then run the batch file per @TravisNave  posting https://forums.autodesk.com/t5/installation-licensing/how-to-reset-autodesk-2020-licensing/td-p/8699662 and then restart software.
Also make sure WIndows UAC is set to not notify before resetting license and starting the application.
Mark Lancaster
Message 25 of 31
Thank you, Mark. I tried this and still got the same message about the
License Manager once I opened Autocad LT 2020. Any other good ideas?!
Going on 4 days without being able to work.....
Message 26 of 31
rkmcswain
That is unfortunate @Anonymous
Are there any Autodesk folks left out there?  @muriel.a | @natasha.l | @Alessandra.G | @crystal.r
R.K. McSwain     | CADpanacea | on twitter
Message 27 of 31
Mark.Lancaster
@Anonymous
Not sure if this will work  or not.  But I have had to do this a few times for others (but it was related to the timeout message they were seeing)..   Just wondering if resetting it this way will help.
Follow the steps here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-License-checkout-timed-out-What-do-you-want-to-do-in-AutoCAD-2020.html using Option #2.
However it requires you to have the full installation media on your machine and step 15 may need to be changed due to the product you're using.
Mark Lancaster
Message 28 of 31
I'll give it a try. Step 2 is requires that I delete this file:
*%LOCALAPPDATA%\Autodesk\Web Services\LoginState.xml* file
How do I find that file?
Thanks.
Message 29 of 31
rkmcswain
  • Open Windows Explorer
  • Literally paste in this path: %LOCALAPPDATA%\Autodesk\Web Services\
Message 30 of 31
AutoCAD Architecture 2020
Message 31 of 31
On Step 10 of Option 2 above the file name I have for Autocad 2020 was different than the one given which was:  C:\Autodesk\AutoCAD_2020_English_win_64bit_dlm\x86\AdskLicensing).
Regardless, I clicked on the file listed and there was nothing listed anything close to what was recommended to run which was: AdskLicensing-installer.exe
Is this a clue to my problem? Could this file be wrong and/or the licensing be missing?
