Error - License checkout timed out
Message 1 of 72
I get a message that the license checkout timed out and autocad lt will shut down. how do I resolve this ?
Replies (71)
Message 2 of 72
pendean
Community Legend
Community Legend
Using what software and year version?
Message 3 of 72
AUtoCad LT 2020
Message 4 of 72
mdavis22569
It's a known issue with AutoCAD and AutoCAD LT 2020:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/The-pr...
Mike Davis
Message 5 of 72
chriscowgill7373
Sorry Mike, that AKN article doesn't seem to help in this case.  I'm getting the same error.  Was working fine after installing, until I rebooted my machine, now none of my 2020 software will run.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 6 of 72
Mark.Lancaster
@chriscowgill7373
Can you confirm is this service is installed and running?
Mark Lancaster
Message 7 of 72
chriscowgill7373
Thank you @Mark.Lancaster   It was installed but not running, odd that my older software would still start up, just not 2020.  Started the service, and 2020 is up and running.  Now on to resolve the 1603 error that is preventing me from installing the toolsets.
*****Edit***
It would appear having the license manager runninghas resolved my 1603 error as well.
*** Edit***
Message 8 of 72
Mark.Lancaster
@chriscowgill7373
That's the new single user/standalone licensing service.   Prior to the 2020 release it used this service
Mark Lancaster
Message 9 of 72
chriscowgill7373
Although this does fix the issue, there seems to be a bigger underlying problem.  Why, every time I reboot, does the license service not start on its own?
Message 10 of 72
Mark.Lancaster
@chriscowgill7373
Is it set to "Automatic"
Mark Lancaster
Message 11 of 72
chriscowgill7373
indeed it is.
Message 12 of 72
Mark.Lancaster
@chriscowgill7373
Usually that tells me the account doesn't have the permission to start the service.   Have you checked your Windows Event logs?
Mark Lancaster
Message 13 of 72
chriscowgill7373
I cannot say I would know where to look.
In the Event viewer, it is showing A timeout was reached (30000 milliseconds) while waiting for the AdskLicensingService service to connect.
Message 14 of 72
Mark.Lancaster
@chriscowgill7373
If you right mouse click on the service and select properties, what account is being used for log on
Mark Lancaster
Message 15 of 72
chriscowgill7373
Shows the same as your screenshot.
Message 16 of 72
Mark.Lancaster
@chriscowgill7373
Right mouse click on the service and select properties.   On the general  tab change startup type to Automatic - Delayed Start and reboot to see if that makes a difference.
Mark Lancaster
Message 17 of 72
chriscowgill7373
That looks like it got the license service to start, but the desktop app service is still not starting.  (not that i really use the desktop app to update anything but Infraworks)
Message 18 of 72
Getting the same issue here.
licensing manager is running and set to automatic.
Autocad will open then after about a minute close with the same message.
This occurred seemingly randomly during use after a few hours then on repeat there on after.
Message 19 of 72
Mark.Lancaster
@Anonymous
I assume this is related to the 2020 product line?
Have you applied the new license hot fix https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Hybrid-Sleep-or-Hibernate-power-settings-impact-on-Autodesk-2020-product-licensing.html?_ga=2.50950505.1995553866.1554295459-47063012.1554295459
Mark Lancaster
Message 20 of 72
w_ebenryter
I have exactly the same problem. There is no other solution than to configure the services manually after running. No license amendment will help. AutoCAD LT 2020 has an error and until Autodesk has developed the fix so it will.
