Error during downloading
Install Autodesk Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
Does anyone know how to fix this issue? thanks in advance.
mpeperkamp
Hi @Anonymous,
Welcome to the Autodesk forum.
It looks like you’re seeing Error 1603. Error 1603 is a generic error generated by the Microsoft Windows Installer (MSI) when a problem occurred during the installation of your Autodesk product. The following article(s) should help you resolve the problem:
Error 1603 during installation of Autodesk software
Errors during AutoCAD software installation
Here is some general information about installation, licensing and downloading Autodesk software:
AutoCAD 2012 installation fails on machine with NET 4.5
Previous Versions of Autodesk Software
Installation, Activation and Licensing
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Darin.Green
This issue is caused by the method you're using to download/install the application.
Solution:
Download the software from the Autodesk Virtual Agent
  • Once there, use Download Links and navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
When i try to use the virtual agent installer this shows up once i open up the thing i downloaded. 'Product download consists of multiple files. At least one file is missing or has not been downloaded yet.
Mark.Lancaster
@Anonymous
That means you didn't download all the parts for your product.  Go back to the virtual agent and download all the parts first before attempting any extraction and installation.
Mark Lancaster
