AutoCad 2014
AutoCad 2014
AutoCad 2014
To whom it may consern,
Can anybody out there help me purchase and install AutoCad 2014, The reason I am looking for AutoCad 2014 is my computer is runing on XP this is do to other software I have that runs on XP, l have install 2014at least five time and when I click oan the AutoCad icon on the destop to open it all I get is no internet and try again and when I check my internet its ok.
Regard Michael
Otto
Hello mmcjoinery1405 and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Just realized you have posted twice about AutoCAD 2014..  But this posting is about AutoCAD 2014 and the other one is about Acad LT 2014.  So which product are you looking at?   Also in the future..  Make one posting with clear information.  Smiley Wink
Unfortunately you can't purchase the 2014 version anymore.  You have to subscribe (rent) to AutoCAD 2017 and then you will get the rights to use the 2014 version.
In addition.. "the destop to open it all I get is no internet and try again and when I check my internet its ok."..  Not sure what you even mean by this statement.  Can you clarify.
Mark Lancaster
Darin.Green
@Anonymous
Solution: You may need to install the Autodesk Poodle Hotfix which is for 2014 & 2015 products as other users were having the same issue. This hotfix may resolve the issue, but as @Mark.Lancaster stated in his post, you'll need to subscribe and request previous version 2014 in order to use it.
Although XP was a great platform, the web calls are becoming obsolete as many are no longer supporting it. That said, things will eventually stop working, in which case, you'll need to upgrade.
Recommendation: Upgrade your machine to Windows 7 and purchase VMWare. Create a virtual machine of your XP OS to use the legacy products, but Windows 7 for everything else.
If this information was helpful, please consider using the Accept Solution
natasha.l
Hello @Anonymous,
As previously mentioned, I understand you may be interested in purchasing AutoCAD LT 2017 or AutoCAD 2017 to have access to the 2014 version.
Contact Us here: Buying Autodesk Software
Regarding the connectivity error I believe you are receiving "Establish an Internet connection to continue"@Darin.Green hot fix should fix it and you may want to try:
Reset Internet Options:
  1. Clear the browser cache
  2. Browse to Control Panel\All Control Panel Items\Internet Option
  3. In the Advanced tab > Reset button to reset Internet Explorer's settings to the defaults
  4. In the Security tab, select Reset All Zones to Default level
  5. In the Content tab, select Clear SSL state
  6. Select Apply
In the Control Panel >> Internet Options >> Connections tab >> LAN settings >> Do you have automatically detect settings enabled?
Temporarily disable Firewall & Antivirus
Keep us posted and thank you for posting! Smiley Happy
