Error 1606:Could not access network location Autodesk\Autocad 2014\R19.1
Message 1 of 27
Hi to everyone is couple of days than i try to install Autocad 2014  on windows 8 64 bits with not success everytime i tried i always get the same error as the picture:
I tried many things as i so in this forum as i saw in other forum ect....
I tried to check the following registry keys:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  and they are as the following pictures:
  • HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
and i check also that:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
And after i checked also the environment variables as you can see in the following picture:
I don't know what else do, i haven't other idea please i need a quick help to fix my problem!   Smiley Sad
Replies (26)
Message 21 of 27
abobadaprojetos
Community Visitor
Community Visitor
I just did what the user "wppdev" said and the problem was fixed! Many thanks!
Message 22 of 27
creating documents folder worked for me!
Message 23 of 27
ben.saa
Autodesk Support
Autodesk Support
For the 2019 version a user has created the missing folders (in his case 2 non-existent folders)
Message 24 of 27
the mkdir solution was what solved it all for me. thx a LOT
Message 25 of 27
Yup, same situation here as well, small SSD for the OS and a 1tb drive for applications.  Creating a Documents folder in C:/Users/Public made installation go smoothly.
Message 26 of 27
I don't find documents folder in user/public so how can I resolve errors 1606
Message 27 of 27
I am on AutoCad 2020 now - the folder is now located here:
C:\Users\Public\Documents\Autodesk
The folder itself is labeled "Public Documents" in File Explorer
This is under Windows 10 64-bit
I hope this helps.
