Downloading and Installing AutoCAD 2017
Message 1 of 13
HELP!!!!  I am having trouble getting AutoCAD 2017 to download and install.  The software appears to download but not install; I have tried several times and get the same several error messages.  I have looked at YouTube videos...asked CAD instructors...tried finding a support number to call...all to no avail.  Is there anyone out there that can help?  Thank you!!!
Replies (12)
Message 2 of 13
Mark.Lancaster
@Anonymous
Welcome to the community
Without the installation log file we can only speculate what the issue may be.  However I will assume its based on the method you're using..
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
Message 3 of 13
I apologize but I do not understand when you say the solution (link) is in your signature.  I was trying to download/install prior to your message.  Again, I got the same error messages...even tried disabling anti-virus/firewall..trying to do a PrintScreen to show some of the error messages but it will not work. Below is the "Installation Log File" detailing what did (not) download/install.  Any help you could provide would be greatly appreciated!!!
2016/8/23:11:14:28 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:11:14:28 ABG SUNSHINE33 Path_Length: 162
2016/8/23:11:14:28 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/23:11:14:28 ABG SUNSHINE33 Launch
2016/8/23:11:14:28 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/23:11:14:28 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI247D.tmp
2016/8/23:11:19:07 ABG SUNSHINE33 === Setup ended ===
2016/8/23:11:14:30 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:11:14:30 ABG SUNSHINE33 Path_Length: 162
2016/8/23:11:14:30 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI247D.tmp
2016/8/23:11:14:30 ABG SUNSHINE33 Launch
2016/8/23:11:15:18 ABG SUNSHINE33 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/23:11:15:18 ABG SUNSHINE33 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/23:11:15:18 ABG SUNSHINE33 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/23:11:19:05 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/23:11:19:05 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI247D.tmp\Setup\AcSetup.dll
2016/8/23:11:19:05 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/23:11:19:09 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/23:11:19:26 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/23:11:19:26 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/23:11:19:26 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/23:11:19:49 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/23:11:19:51 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:11:19:51 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:11:19:51 ABG SUNSHINE33 Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:19:58 ABG SUNSHINE33 Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:19:58 ABG SUNSHINE33 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/8/23:11:20:37 ABG SUNSHINE33 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/8/23:11:20:38 ABG SUNSHINE33 Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:20:46 ABG SUNSHINE33 Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:20:46 ABG SUNSHINE33 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/8/23:11:21:40 ABG SUNSHINE33 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/8/23:11:21:40 ABG SUNSHINE33 Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:21:50 ABG SUNSHINE33 Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:21:50 ABG SUNSHINE33 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/8/23:11:23:27 ABG SUNSHINE33 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/8/23:11:23:27 ABG SUNSHINE33 Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/23:11:23:34 ABG SUNSHINE33 Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/23:11:23:34 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/23:11:23:35 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/23:11:23:35 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:23:56 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:23:56 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/23:11:24:01 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/23:11:24:01 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:24:21 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:24:21 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/23:11:24:31 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/23:11:24:32 ABG SUNSHINE33 Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/23:11:24:54 ABG SUNSHINE33 Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/23:11:24:54 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/23:11:25:36 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/23:11:25:37 ABG SUNSHINE33 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/23:11:33:10 ABG SUNSHINE33 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/23:11:33:10 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/23:11:33:13 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/23:11:33:13 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/23:11:33:13 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/23:11:33:13 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/8/23:11:33:13 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/8/23:11:34:31 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/23:11:35:34 ABG SUNSHINE33 === Setup ended ===
2016/8/23:11:38:43 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:11:38:43 ABG SUNSHINE33 Path_Length: 162
2016/8/23:11:38:43 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/23:11:38:43 ABG SUNSHINE33 Launch
2016/8/23:11:38:43 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/23:11:38:43 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI4CBA.tmp
2016/8/23:11:39:30 ABG SUNSHINE33 === Setup ended ===
2016/8/23:11:39:08 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:11:39:08 ABG SUNSHINE33 Path_Length: 162
2016/8/23:11:39:08 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI4CBA.tmp
2016/8/23:11:39:08 ABG SUNSHINE33 Launch
2016/8/23:11:39:10 ABG SUNSHINE33 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/23:11:39:10 ABG SUNSHINE33 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/23:11:39:11 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI4CBA.tmp\Setup\AcSetup.dll
2016/8/23:11:39:11 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/23:11:39:22 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/23:11:40:55 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/23:11:40:55 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/23:11:40:57 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/23:11:41:14 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/23:11:41:15 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:11:41:18 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:11:41:19 ABG SUNSHINE33 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/23:11:41:19 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/23:11:41:20 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/23:11:41:20 ABG SUNSHINE33 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:41:20 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/23:11:41:25 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/23:11:41:25 ABG SUNSHINE33 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:11:41:25 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/23:11:41:29 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/23:11:41:29 ABG SUNSHINE33 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/23:11:41:29 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/23:11:42:43 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/23:11:42:43 ABG SUNSHINE33 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/23:11:50:20 ABG SUNSHINE33 Download Complete CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/23:11:50:21 ABG SUNSHINE33 Installing Autodesk Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2A15F7EE-CBC6-477D-91A7-B85DC3E88518} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/8/23:11:51:58 ABG SUNSHINE33 Install Autodesk Material Library 2017 Succeeded
2016/8/23:11:52:01 ABG SUNSHINE33 Download Play CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/23:11:53:55 ABG SUNSHINE33 Download Aborted CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/23:11:53:55 ABG SUNSHINE33 Install Autodesk Material Library 2017 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/8/23:11:54:24 ABG SUNSHINE33 Rollback Autodesk Material Library 2017 Succeeded
2016/8/23:11:54:24 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/23:11:54:24 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/23:11:54:24 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/23:11:54:30 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/23:11:55:52 ABG SUNSHINE33 === Setup ended ===
2016/8/23:12:03:34 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:12:03:34 ABG SUNSHINE33 Path_Length: 162
2016/8/23:12:03:34 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/23:12:03:34 ABG SUNSHINE33 Launch
2016/8/23:12:03:34 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/23:12:03:34 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI154F.tmp
2016/8/23:12:03:46 ABG SUNSHINE33 === Setup ended ===
2016/8/23:12:03:41 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/23:12:03:41 ABG SUNSHINE33 Path_Length: 162
2016/8/23:12:03:41 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI154F.tmp
2016/8/23:12:03:41 ABG SUNSHINE33 Launch
2016/8/23:12:03:44 ABG SUNSHINE33 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/23:12:03:44 ABG SUNSHINE33 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/23:12:03:45 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI154F.tmp\Setup\AcSetup.dll
2016/8/23:12:03:45 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/23:12:03:47 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/23:12:04:06 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/23:12:04:06 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/23:12:04:06 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/23:12:04:19 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/23:12:04:19 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:12:04:20 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/23:12:04:20 ABG SUNSHINE33 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/23:12:04:20 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/23:12:04:21 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/23:12:04:21 ABG SUNSHINE33 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:12:04:21 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/23:12:04:24 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/23:12:04:24 ABG SUNSHINE33 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/23:12:04:24 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/23:12:04:24 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/23:12:04:24 ABG SUNSHINE33 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/23:12:04:24 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/23:12:04:37 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/23:12:04:37 ABG SUNSHINE33 Download Skipped CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/23:12:04:37 ABG SUNSHINE33 Installing Autodesk Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2A15F7EE-CBC6-477D-91A7-B85DC3E88518} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/8/23:12:05:19 ABG SUNSHINE33 Install Autodesk Material Library 2017 Succeeded
2016/8/23:12:05:19 ABG SUNSHINE33 Download Play CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/23:12:07:17 ABG SUNSHINE33 Download Aborted CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/23:12:07:17 ABG SUNSHINE33 Install Autodesk Material Library 2017 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/8/23:12:07:39 ABG SUNSHINE33 Rollback Autodesk Material Library 2017 Succeeded
2016/8/23:12:07:39 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/23:12:07:39 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/23:12:07:39 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/23:12:07:43 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/23:12:07:56 ABG SUNSHINE33 === Setup ended ===
2016/8/24:22:53:21 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/24:22:53:21 ABG SUNSHINE33 Path_Length: 162
2016/8/24:22:53:21 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2016/8/24:22:53:21 ABG SUNSHINE33 Launch
2016/8/24:22:53:21 ABG SUNSHINE33 CommandLine /akamai /sid a1b3A000000GYlAQAW /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S...
2016/8/24:22:53:21 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI52BD.tmp
2016/8/24:23:09:07 ABG SUNSHINE33 === Setup ended ===
2016/8/24:22:53:24 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/24:22:53:24 ABG SUNSHINE33 Path_Length: 162
2016/8/24:22:53:24 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI52BD.tmp
2016/8/24:22:53:24 ABG SUNSHINE33 Launch
2016/8/24:22:53:30 ABG SUNSHINE33 Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/24:22:53:32 ABG SUNSHINE33 Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/24:22:53:33 ABG SUNSHINE33 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/24:23:09:05 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/24:23:09:06 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI52BD.tmp\Setup\AcSetup.dll
2016/8/24:23:09:06 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/24:23:09:07 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/24:23:09:49 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/24:23:09:49 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/24:23:09:50 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/24:23:09:57 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/24:23:09:58 ABG SUNSHINE33 Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/24:23:09:58 ABG SUNSHINE33 Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/24:23:09:59 ABG SUNSHINE33 Download Play UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/24:23:10:27 ABG SUNSHINE33 Download Complete UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/24:23:10:27 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/24:23:10:27 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/24:23:10:28 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/24:23:11:29 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/24:23:11:29 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/24:23:12:03 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/24:23:12:04 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/24:23:13:11 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/24:23:13:11 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/24:23:13:12 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/24:23:13:13 ABG SUNSHINE33 Download Play DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/24:23:14:25 ABG SUNSHINE33 Download Complete DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/24:23:14:25 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/24:23:14:38 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/24:23:14:39 ABG SUNSHINE33 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/24:23:37:15 ABG SUNSHINE33 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/24:23:37:15 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/24:23:37:18 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/24:23:37:18 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/24:23:37:18 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/24:23:37:32 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/25:00:32:48 ABG SUNSHINE33 === Setup ended ===
2016/8/25:09:01:13 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:09:01:13 ABG SUNSHINE33 Path_Length: 162
2016/8/25:09:01:13 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/25:09:01:13 ABG SUNSHINE33 Launch
2016/8/25:09:01:13 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/25:09:01:13 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AID441.tmp
2016/8/25:09:01:30 ABG SUNSHINE33 === Setup ended ===
2016/8/25:09:01:22 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:09:01:22 ABG SUNSHINE33 Path_Length: 162
2016/8/25:09:01:22 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AID441.tmp
2016/8/25:09:01:22 ABG SUNSHINE33 Launch
2016/8/25:09:01:24 ABG SUNSHINE33 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/25:09:01:24 ABG SUNSHINE33 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/25:09:01:25 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AID441.tmp\Setup\AcSetup.dll
2016/8/25:09:01:25 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/25:09:01:27 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/25:09:03:03 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/25:09:03:03 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/25:09:03:05 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/25:09:03:24 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/25:09:03:26 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:09:03:27 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:09:03:27 ABG SUNSHINE33 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/25:09:03:27 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/25:09:03:27 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/25:09:03:28 ABG SUNSHINE33 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:09:03:28 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/25:09:03:32 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/25:09:03:32 ABG SUNSHINE33 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:09:03:32 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/25:09:03:33 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/25:09:03:33 ABG SUNSHINE33 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/25:09:03:33 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/25:09:04:02 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/25:09:04:02 ABG SUNSHINE33 Download Skipped CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/25:09:04:02 ABG SUNSHINE33 Installing Autodesk Material Library 2017:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={2A15F7EE-CBC6-477D-91A7-B85DC3E88518} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/8/25:09:05:27 ABG SUNSHINE33 Install Autodesk Material Library 2017 Succeeded
2016/8/25:09:05:28 ABG SUNSHINE33 Download Play CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/25:09:05:49 ABG SUNSHINE33 Download Aborted CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CMILB.tar...
2016/8/25:09:05:49 ABG SUNSHINE33 Install Autodesk Material Library 2017 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/8/25:09:06:20 ABG SUNSHINE33 Rollback Autodesk Material Library 2017 Succeeded
2016/8/25:09:06:20 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/25:09:06:20 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/25:09:06:20 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/25:09:06:29 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/25:10:14:27 ABG SUNSHINE33 === Setup ended ===
2016/8/25:10:22:53 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:10:22:53 ABG SUNSHINE33 Path_Length: 162
2016/8/25:10:22:53 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/25:10:22:53 ABG SUNSHINE33 Launch
2016/8/25:10:22:53 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/25:10:22:53 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI9EDC.tmp
2016/8/25:10:25:42 ABG SUNSHINE33 === Setup ended ===
2016/8/25:10:22:56 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:10:22:56 ABG SUNSHINE33 Path_Length: 162
2016/8/25:10:22:56 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI9EDC.tmp
2016/8/25:10:22:56 ABG SUNSHINE33 Launch
2016/8/25:10:23:01 ABG SUNSHINE33 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/25:10:23:01 ABG SUNSHINE33 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/25:10:23:04 ABG SUNSHINE33 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/25:10:25:41 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/25:10:25:41 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI9EDC.tmp\Setup\AcSetup.dll
2016/8/25:10:25:41 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/25:10:25:43 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/25:10:26:57 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/25:10:26:57 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/25:10:26:57 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/25:10:27:04 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/25:10:27:04 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:10:27:05 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:10:27:05 ABG SUNSHINE33 Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/25:10:27:10 ABG SUNSHINE33 Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/25:10:27:10 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/25:10:27:10 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/25:10:27:10 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:10:27:23 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:10:27:23 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/25:10:27:25 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/25:10:27:26 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:10:27:41 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:10:27:41 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/25:10:27:42 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/25:10:27:43 ABG SUNSHINE33 Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/25:10:28:01 ABG SUNSHINE33 Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/25:10:28:01 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/25:10:28:14 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/25:10:28:14 ABG SUNSHINE33 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/25:10:32:38 ABG SUNSHINE33 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/25:10:32:38 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/25:10:32:39 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/25:10:32:39 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/25:10:32:39 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/25:10:32:39 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/25:11:17:50 ABG SUNSHINE33 === Setup ended ===
2016/8/25:11:29:45 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:11:29:45 ABG SUNSHINE33 Path_Length: 162
2016/8/25:11:29:45 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/8/25:11:29:45 ABG SUNSHINE33 Launch
2016/8/25:11:29:45 ABG SUNSHINE33 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2016/8/25:11:29:45 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AIDE0F.tmp
2016/8/25:11:33:47 ABG SUNSHINE33 === Setup ended ===
2016/8/25:11:29:46 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:11:29:46 ABG SUNSHINE33 Path_Length: 162
2016/8/25:11:29:46 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AIDE0F.tmp
2016/8/25:11:29:46 ABG SUNSHINE33 Launch
2016/8/25:11:29:49 ABG SUNSHINE33 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/25:11:29:50 ABG SUNSHINE33 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/8/25:11:29:51 ABG SUNSHINE33 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/25:11:33:46 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/8/25:11:33:46 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AIDE0F.tmp\Setup\AcSetup.dll
2016/8/25:11:33:46 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/25:11:33:46 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/25:11:35:02 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/25:11:35:02 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/25:11:35:02 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/25:11:35:09 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/25:11:35:09 ABG SUNSHINE33 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:11:35:09 ABG SUNSHINE33 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/8/25:11:35:09 ABG SUNSHINE33 Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/25:11:35:21 ABG SUNSHINE33 Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/8/25:11:35:21 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/25:11:35:21 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/25:11:35:21 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:11:35:42 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:11:35:42 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/25:11:35:43 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/25:11:35:43 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:11:36:12 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/8/25:11:36:12 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/25:11:36:12 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/25:11:36:12 ABG SUNSHINE33 Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/25:11:36:47 ABG SUNSHINE33 Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/8/25:11:36:47 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/25:11:36:56 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/25:11:36:56 ABG SUNSHINE33 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/25:11:45:09 ABG SUNSHINE33 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/8/25:11:45:09 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/25:11:45:09 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/25:11:45:09 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/25:11:45:09 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/25:11:45:10 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/25:11:48:00 ABG SUNSHINE33 === Setup ended ===
2016/8/25:11:56:37 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:11:56:37 ABG SUNSHINE33 Path_Length: 162
2016/8/25:11:56:37 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2016/8/25:11:56:37 ABG SUNSHINE33 Launch
2016/8/25:11:56:37 ABG SUNSHINE33 CommandLine /akamai /sid a1b3A000000GkVJQA0 /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S...
2016/8/25:11:56:37 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AIB6EE.tmp
2016/8/25:11:58:54 ABG SUNSHINE33 === Setup ended ===
2016/8/25:11:56:39 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/25:11:56:39 ABG SUNSHINE33 Path_Length: 162
2016/8/25:11:56:39 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AIB6EE.tmp
2016/8/25:11:56:39 ABG SUNSHINE33 Launch
2016/8/25:11:56:42 ABG SUNSHINE33 Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/25:11:56:43 ABG SUNSHINE33 Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/25:11:56:43 ABG SUNSHINE33 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/25:11:58:52 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/25:11:58:53 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AIB6EE.tmp\Setup\AcSetup.dll
2016/8/25:11:58:53 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/25:11:58:54 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/25:11:59:07 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/25:11:59:07 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/25:11:59:07 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/25:12:01:45 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/25:12:01:46 ABG SUNSHINE33 Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/25:12:01:48 ABG SUNSHINE33 Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/25:12:01:48 ABG SUNSHINE33 Download Play UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/25:12:01:53 ABG SUNSHINE33 Download Complete UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/25:12:01:53 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/25:12:01:54 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/25:12:01:54 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/25:12:02:02 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/25:12:02:02 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/25:12:02:16 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/25:12:02:16 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/25:12:02:25 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/25:12:02:25 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/25:12:02:28 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/25:12:02:28 ABG SUNSHINE33 Download Play DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/25:12:02:37 ABG SUNSHINE33 Download Complete DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/25:12:02:37 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/25:12:03:08 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/25:12:03:08 ABG SUNSHINE33 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/25:12:07:40 ABG SUNSHINE33 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/25:12:07:40 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/25:12:07:41 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/25:12:07:41 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/25:12:07:41 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/8/25:12:07:44 ABG SUNSHINE33 PageOpen InstallCompleteDialog
2016/8/25:12:08:22 ABG SUNSHINE33 === Setup ended ===
2016/8/26:16:58:13 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/26:16:58:13 ABG SUNSHINE33 Path_Length: 162
2016/8/26:16:58:13 ABG SUNSHINE33 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2016/8/26:16:58:13 ABG SUNSHINE33 Launch
2016/8/26:16:58:13 ABG SUNSHINE33 CommandLine /akamai /sid a1b3A000009Xwj1QAC /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S...
2016/8/26:16:58:13 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI32EB.tmp
2016/8/26:17:13:45 ABG SUNSHINE33 === Setup ended ===
2016/8/26:16:58:15 ABG SUNSHINE33 === Setup started on SUNSHINE33 by ABG ===
2016/8/26:16:58:15 ABG SUNSHINE33 Path_Length: 162
2016/8/26:16:58:15 ABG SUNSHINE33 Current Directory C:\Users\ABG\AppData\Local\Temp\_AI32EB.tmp
2016/8/26:16:58:15 ABG SUNSHINE33 Launch
2016/8/26:16:58:23 ABG SUNSHINE33 Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/26:16:58:24 ABG SUNSHINE33 Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/26:16:58:25 ABG SUNSHINE33 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/26:17:13:39 ABG SUNSHINE33 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/8/26:17:13:42 ABG SUNSHINE33 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ABG\AppData\Local\Temp\_AI32EB.tmp\Setup\AcSetup.dll
2016/8/26:17:13:42 ABG SUNSHINE33 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/26:17:13:46 ABG SUNSHINE33 PageOpen LaunchDialog
2016/8/26:17:14:11 ABG SUNSHINE33 PageOpen LicenseDialog
2016/8/26:17:14:11 ABG SUNSHINE33 PageOpen ProductInfoDialog
2016/8/26:17:14:11 ABG SUNSHINE33 PageOpen ProductSelectionDialog2
2016/8/26:17:14:28 ABG SUNSHINE33 PageOpen FullProgressDialog
2016/8/26:17:14:29 ABG SUNSHINE33 Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/26:17:14:29 ABG SUNSHINE33 Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/8/26:17:14:30 ABG SUNSHINE33 Download Play UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/26:17:14:58 ABG SUNSHINE33 Download Complete UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/8/26:17:14:58 ABG SUNSHINE33 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/8/26:17:15:00 ABG SUNSHINE33 Install Universal C Runtime (KB3118401) Succeeded
2016/8/26:17:15:01 ABG SUNSHINE33 Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/26:17:16:03 ABG SUNSHINE33 Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/26:17:16:03 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x86_2015.log
2016/8/26:17:16:50 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/8/26:17:16:51 ABG SUNSHINE33 Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/26:17:18:10 ABG SUNSHINE33 Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/8/26:17:18:10 ABG SUNSHINE33 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ABG\AppData\Local\Temp\vcredist_x64_2015.log
2016/8/26:17:18:12 ABG SUNSHINE33 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/8/26:17:18:14 ABG SUNSHINE33 Download Play DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/26:17:19:30 ABG SUNSHINE33 Download Complete DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/8/26:17:19:30 ABG SUNSHINE33 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/8/26:17:19:48 ABG SUNSHINE33 Install DirectX Runtime Succeeded
2016/8/26:17:19:49 ABG SUNSHINE33 Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/26:17:45:30 ABG SUNSHINE33 Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/8/26:17:45:30 ABG SUNSHINE33 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/8/26:17:45:35 ABG SUNSHINE33 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/8/26:17:45:35 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/8/26:17:45:35 ABG SUNSHINE33 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Message 4 of 13
Mark.Lancaster
@Anonymous
Please stop using the method you are using that is why its failing to install..  You are trying to download and install using the web installer and it keeps failing..  Its not going to work.
However we found out an about an hour ago the link in the Autodesk VIrtual Agent for AutoCAD 2017 is downloading Acad LT 2017...  The link to the Autodesk Virtual Agent is my signature if you look at my reply on-line.
So instead, download both parts here if you have a 64bit operating system, do you?
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/DLM/AutoCAD_2017_English_Win_64bit_dlm_001_002.sfx.exe?authparam=1474045258_2eec0e7b7b24e3ebe3bf4c6b422a9988&ext=.exe
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/DLM/AutoCAD_2017_English_Win_64bit_dlm_002_002.sfx.exe?authparam=1474045355_18acffed3094edbeeb0a0bb741d301d1&ext=.exe
1. Download all of the parts for your product first. Do not continue until all of the parts have fully downloaded.
2. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe
3. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
4. Once the extraction is finished, the installation will automatically start.
5. Follow the installation steps for your product
Update:  Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
Message 5 of 13
I will try this. THANK YOU. Should I uninstall any parts that did install before trying the solution in this email?
~Anna
Message 6 of 13
Mark.Lancaster
@Anonymous
Anything that got installed before it failed, most likely got uninstalled but even if it didn't, the method you will be using will skip over those items.   However you could still run into a situation and this new method could still fail since you have tried it already a couple of times already..  Smiley Wink
Mark Lancaster
Message 7 of 13
I am trying to install using the two links you just sent in the email - I checked software installs and did not see anything related to AutoCAD, so hopefully this will work.  If the installation continues to fail, what can I do?  Or am I out of luck?
Your help is greatly appreciated!!!  For all of your travel needs:  (http://www.travlnbgud.com/) For Business Opportunity:  (http://www.travlnbgud.info/)
Message 8 of 13
Mark.Lancaster
It sounds like you are not following the steps I provided.  The links I sent do not and I mean do not install anything..  You are just downloading the compressed installation files to your machine.
You have to go to your download location and double click on part 1 of the 2 parts you downloaded.   From there it will start the extraction and then it will prompt you to extract to C:\Autodesk...  Once the extraction is completed the installation will take place.
Mark Lancaster
Message 9 of 13
That's just it - I do not see a Part 1 or 2. Either nothing downloaded or I do not know where to look to see if it downloaded; the latter is more likely. There is nothing under "Programs."
When I go to the website, my options are to download...which you said not to do.
Is there someone that I can speak with? I am trying...
~Anna
Message 10 of 13
Mark.Lancaster
@Anonymous
When you click on each of the links I gave to you earlier, you should see a message like this?  Are you seeing this?  Are you select Save?
Mark Lancaster
Message 11 of 13
I think I follow now...currently installing Part 1...
~Anna
Message 12 of 13
Mark.Lancaster
Are you just downloading part 1 for the link or did you already download and you are trying to install?  You need both parts downloaded first...
Mark Lancaster
Message 13 of 13
ameliareva767
Community Visitor
Community Visitor
DOWMLOAD
