Data Privacy pop-up hangs/delays programs startups
dpalmerVQ54W
Message 1 of 11
dpalmerVQ54W
When I launch either ACAD 2021 or Navisworks Freedom 2021 I get the following:
The blue circles around for a number of seconds, as much as 30 seconds or more. Eventually it disappears and the program starts. This occurs when I'm working from either my company's office, or if I'm working from home (either connected to the company VPN or not).
It's only just started after applying a number of updates that came from the Autodesk App.
Any suggestion on stopping this would be grateful.
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
David P
AutoCAD 2021; AutoCAD 2026; Navisworks Manage & Freedom
Replies (10)
Message 2 of 11
rushabhthakkar_910
Have a look at this..!!
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Progra...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 11
rushabhthakkar_910
If your issue has been solved, mark the post as Solved. So that it can help others too in future who are looking for similar issues.
If not, share details as to where you are stuck. And we'll try to help you out.
Thanks and Regards,
Rushabh Thakkar.
Message 4 of 11
mdavis22569
@rushabhthakkar_910
Slow down on the answer .. review a bit more
@dpalmerVQ54W mentions:
So slow loading AutoCAD AKN helps how?
They are asking about the Data Privacy popup too..
@dpalmerVQ54W
Make sure you have this:
Which URLs/Protocols need to be white listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Maybe try with the firewall off and see if you have any issues:
Mike Davis
Message 5 of 11
mdavis22569
@rushabhthakkar_910
@dpalmerVQ54W
Mike Davis
Message 6 of 11
Simon_Weel
Message 7 of 11
DunbarR1
Observer
Observer
Is there an answer on how to get rid of this annoying Data Privacy popup that I also get when starting AutoCAD LT 2022? It started after an update.
Message 8 of 11
Simon_Weel
It should only pop up once. You can also change / set your privacy settings on your Autodesk Account page. Maybe that will suppress the message?
Message 9 of 11
halukuzuner
I tried whatever I found in Autodesk forums. But none of them worked for me. Dear Autodesk management please submit a working resolution for this problem.
Message 10 of 11
mdavis22569
Do you have Admin rights on the PC?
Mike Davis
Message 11 of 11
halukuzuner
Yes, I have administrator rights.
