Message 1 of 1
I cant install autocad 2025
I had autocad 2018, I decided to update to autocad 2025 (at least test it) but when I tried to install autocad there is a problem, this the problem I opened the autocad installer and suddenly It dissapear, I try to delete all the file of the autocad old version It doesnt work same problem, tried to reinstall all the redistributable windows versions same problem, probably after many tried there could be a issue with that, tried with autocad 2026 same problem , I use W11 , I dont know what to do, thanks in advance for your help.
No puedo instalar Autocad 2014 ni la versión 2013.
No puedo instalar ninguna versión y tengo dos PC diferentes y en ninguna de estas me funciona.
El error que me sale es el siguiente:ERROR FATAL Unhandled Access Vilation Writing 0x70cdf290 exception at 70cdf290h
Los datos de la PC son los siguientes:
Procesador:m AMD A10-7860K Radeon R7 a 3.60 GHz
8 Gb de Ram
Tarjeta Gráfica: AMD Radeon (TM) R7 Graphics
Autocad genera un informe y este dice lo siguiente: Firma de error, excepción sin gestionar
8 Gb de Ram
