CFD 2019 crashes on startup (access violation, error 0xC0000005)
I recently installed CFD 2019 Ultimate as I have a student license besides Inventor 2020 Pro, which is working perfectly fine, but when I started up CFD at the first time, I got a crash with a dump file, which said "The thread tried to read from or write to a virtual address for which it does not have the appropriate access." and error 0xC0000005. Also, I noticed that the serial num in the dmpuserinfo.xml is not matching with my serial num. As I cannot access the program to change that, how can this be solved?
Which version do you have?
I would say that if you have the latest version then try to reinstall CFD and see if it solves the problem.
I tried reinstalling it multiple times, twice clear uninstalled, twice the whole autodesk library uninstalled. Checked registers, I have the latest version, CFD 2019 Ultimate.
Mark.Lancaster
@Anonymous
See this https://knowledge.autodesk.com/support/cfd/troubleshooting/caas/sfdcarticles/sfdcarticles/CFD-crashe... and https://forums.autodesk.com/t5/installation-licensing/autodesk-cfd-2019-crashes-on-launch/td-p/79968...
Mark Lancaster
Tried both, twice, didn't work.
