cannot install Inventor 2023
lukas_tilch
Message 1 of 25
lukas_tilch
When I try to install Inventor, I get this message.
I have tried this already.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Clean...
I had the same problem a while back, the only solution was to reinstall Windows.
This is beyond annoying. If this Problem persists, I will switch to SolidWorks.
Inventor is a buggy mess.
Windows version info:
Replies (24)
Message 2 of 25
rushabhthakkar_910
@lukas_tilch, Have you tried this..?
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cannot....)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 25
lukas_tilch
That ist not the problem.
Message 4 of 25
mdavis22569
Share a screenshot of your WINVER  / Windows version to the ticket
Mike Davis
Message 5 of 25
mdavis22569
There is an update for Window 11 available
Try updates and doing the Microsoft FixIt tool
Mike Davis
Message 6 of 25
lukas_tilch
Windows doesn't list this as an available update
Message 7 of 25
mdavis22569
Odd, as you can see from my image ( from this pc) that 22H2 is possible.
Can you share the WINVER like my image?
Mike Davis
Message 8 of 25
rushabhthakkar_910
@lukas_tilch shared it in OP. (WINVER)
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 25
mdavis22569
No that's not the WINVER   that's the ABOUT your PC settings.  There is a different.  And why I asked for the WINVER by command not ABOUT by command @rushabhthakkar_910
Mike Davis
Message 10 of 25
mdavis22569
@lukas_tilch
Just checking in to see if you were able to get it installed?
Also, did you try a new Windows Profile for the installation?
Can you share the Winver still?
Mike Davis
Message 11 of 25
lukas_tilch
I have not been able to install it.
As for the winver, I'm unable to see what information is missing from the screenshot I shared.
To me, it looks like only the ordering is different.
The Version in winver is this:
Microsoft Windows
Version 21H2 (OS Build 22000.1281)
That is identical to the about page.
Message 12 of 25
mdavis22569
No mine is 22H2, it's updated.
I'm trying to get you to update your Windows fully and then try the installation
Mike Davis
Message 13 of 25
lukas_tilch
Windows is not showing the update you are referring to, as stated in message 6 in this thread.
I was able to install Autocad and 3ds Max without an issue.
Message 14 of 25
mdavis22569
OK .. but I showed you that there is an update available. As I have, it installed on 2 machines.
put a support ticket in and see if Autodesk can help then.
I would say do a clean uninstall or Windows reinstall. But I don't think that'll go over well
Mike Davis
Message 15 of 25
rushabhthakkar_910
@lukas_tilch, I also have 22H2 installed like @mdavis22569 has..!!
Thanks and Regards,
Rushabh Thakkar.
Message 16 of 25
lukas_tilch
I do not doubt that this update exists, as I have it installed on another machine as well.
Yet this does not explain why the Inventor installer is seemingly incompatible with this updated Windows 11 I have installed in August 2022.
My guess would be, that the Installer has checks in place to determine whether the previous installation is fully removed from the system, before installing a new one.
Which in and of itself is a good idea, but if I have to remove files and edit the registry manually as suggested in the "Clean Uninstall" and it is still not working, something is definitively wrong with these checks.
At this point it is just not worth spending any more time on this.
I will use this time to get more familiar with solid works instead.
But I thank both of you, rushabhthakkar_910 and mdavis22569, for at least trying to help me
Message 17 of 25
rushabhthakkar_910
@lukas_tilch, Contact support once to see if they can help you out with this..!!
https://www.autodesk.com/support/contact-support
Thanks and Regards,
Rushabh Thakkar.
Message 18 of 25
mdavis22569
@lukas_tilch
I'd do a ticket
https://www.autodesk.com/support/contact-support?_ga=2.48969958.1191322558.1670940499-1971025296.167...
Let us know .. but without being on your PC, it's just a bunch of try this or that now
Mike Davis
Message 19 of 25
gkniksch_aep
Unfortunately, I'm running into this same problem myself. Used the clean uninstall instructions as well. I put in a support case, hoping for some help soon. Has there been any updates to this issue not yet documented here? Thanks.
Message 20 of 25
gkniksch_aep
I figured out my issue. When performing the clean uninstall, there was one more place that needed to be hit in the registry. There was still a location existing in the Installer Products that was telling the installer that Inventor 2023 was still installed:
  • Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\
This resulted in the message shown in the original post for me. Once I deleted the location pointing at the Inventor.exe, I was able to finish the re-install normally. Maybe this will help others in the future. Thanks.
