Cannot connect to the license server system
Hi everyone,
I'm trying to use generate my license server configuration but but when i try reread on LMTOOLS i get an error saying that
adskflex: Cannot connect to license server system.
I'm posting the screenshot of the error and attaching the license log file
Can anyone help me?, i already tryed with searching on the flexera softaware site and i failed.
Thank you
Gerardo Ochoa
DarrenP
you maybe running into a port conflict
try adding another port in the license file
more details: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-change-the-assigne...
DarrenP
Hi darren, i performed the steps but i still getting the same message.
I review the log file, and i found this
12:45:38 (adskflex) Server started on GERARDO-PC for:
12:45:38 (adskflex) 77800MFS_F (consisting of: 86558MFS_2016_0F
12:45:38 (adskflex) 86326MFS_2015_0F 86158MFS_2014_0F 86012MFS_2013_0F)
12:45:38 (adskflex) 76800MFAA_F (consisting of: 86576MFAA_2016_0F
12:45:38 (adskflex) 86322MFAA_2015_0F 86152MFAA_2014_0F 86007MFAA_2013_0F)
12:45:38 (adskflex) 64801INVPROSA_F (consisting of: 86497INVPROSA_2016_0F
12:45:38 (adskflex) 86318INVPROSA_2015_0F 86163INVPROSA_2014_0F 86001INVPROSA_2013_0F)
12:45:38 (adskflex) 86501NINCAD_F (consisting of: 86580NINCAD_2016_0F
12:45:38 (adskflex) 86500NINCAD_2015_0F) 86557MFIA_2016_0F
12:45:38 (adskflex) EXTERNAL FILTERS are OFF
12:45:38 (lmgrd) adskflex using TCP-port 0
12:45:38 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
12:45:38 (adskflex) tcp_s is bad!!! Exiting
12:45:38 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
I'm not an expert but i guess if the adskflex is trying to use the TCP port 0.
This is the error message (i returned to the first port number 27000)
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: 192.168.1.72
License path: 27000@GERARDO-PC;
FlexNet Licensing error:-15,578. System Error: 10049 "WinSock: Invalid address"
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Thank you
Gerardo
DarrenP
the error message mentions that the host name could have been changed
try changing the hostname in the license file to the Ip address instead of the hostname
also verify your firewall is not blocking these ports
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
DarrenP
