can't install Inventor 2020 error
Message 1 of 9
Hello! I'm a high school student from Taiwan
I can't install Inventor 2020,can somebody help me? Thanks!
Autodesk Licensing,I don't know how to fix it
Replies (8)
Message 2 of 9
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is an English speaking forum so we have no way of knowing what it states after Autodesk Licensing.  Can you provide the installation log file so we can review it
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Location-of-the-log-files-generated-by-the-installation-of-an-Autodesk-product.html
Also check to see if this Windows service is there and started
Mark Lancaster
Message 3 of 9
It's saying the install haven't finished. Some products cant' install.
                 Auto Licensing haven't installed (error:1)
Is this one?
Yes , it's start
Message 4 of 9
Mark.Lancaster
@Anonymous
Not sure what you are showing under "is this one"
Also looking at the service..  Too me it doesn't look started...   You should be seeing who (which account) is running that service..
Mark Lancaster
Message 5 of 9
Oh no, seems I gave you the wrong information, sorry about that
And I found there are some mistakes,it's always appear everytime I install
This one is in services.msc,and it's also works
Message 6 of 9
Mark.Lancaster
@Anonymous
Don't provide a screen shot of a portion of log file.   Attach the entire log file for review..  Just because you underlined the word error doesn't mean that's the issue.   Actually the issue is a few lines above it where it stating the installation was aborted.
What sub-folders are located here C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing
Mark Lancaster
Message 7 of 9
ok
Here
Message 8 of 9
Mark.Lancaster
@Anonymous
Is there a reason why you can't attach the log file?   Images of your log file is not helpful as I already indicated...
In addition it doesn't appear your licensing mechanism was fully installed properly.
Mark Lancaster
Message 9 of 9
Hi@s17854269,
Thanks for your feedback.
The screenshot you sent is some times due to incomplete download files..
could you please check the popup blocker is  enabled or not?
Could you please deleted the download files from Dowload folder and c:/autodesk folder and restart the system and then re-download the files and install?
Could you please check the following articles also?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/discussion/t5/Inventor-Forum/In...
Please let us know if it works.
Srinivas.
