Autodesk Identity Manager - Update
monica_l_lee
monica_l_lee
We are making a new ACAD 2025 deployment, the Autodesk Identity Manager that is bundled in is the an older version of the Autodesk Identity Manager. When we run out deployment for ACAD 2025 that installs properly but when we try to apply the update for the Autodesk Identity Manager using the code below it won't install silently. Any suggestions ?
AdskIdentityManager-update.exe --mode unattended
Simon_Weel
I use AdskIdentityManager-UCT-Installer_11505.exe -q
kamaljeet_singhEMUD6
Community Visitor
Community Visitor
Dear Monica,
I tried below command but installation window pop-up for to click on install.
AdskIdentityManager-UCT-Installer\Setup.exe" -Parameters "--mode unattended --unattendedmodeui none"
Community Visitor
Community Visitor
Even I tried -q but again it is pop-up for installation. Kindly suggest to install the parameter for silent installation
Execute-Process -Path "$dirFiles\AdskIdentityManager-UCT-Installer\Setup.exe" -Parameters "-q"
omushahwar
If you are running in powershell call it from command prompt as a lot of Autodesk programs do not launch well/correctly from powershell.
cmd.exe /c "C:\Autodesk\AdskIdentityManager-UCT-Installer.exe -q"
jmeidinger
Observer
Observer
thank you
