AutoCAD 2023 run error: "pm16.dll" Module Not Found
d.nykiel
Message 1 of 33
d.nykiel
Hello everybody,
today I try to install and run new AutoCAD 2023 app. When i try run the installed app i have error wchich is schowed in attached screenschoot. On the same device I have AutoCAD 2022 app and it works fine. I have already installed AC2023 on two other devices and they work fine.
I try to reinstall this many times and install with different instalation and download options. I also tried instruction form this topic: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-...
but the error still exist.
I hope you can help me.
Replies (32)
Message 2 of 33
natasha.l
Hello @d.nykiel
Thanks for sharing the steps you have taken thus far.
When you attempted to reinstall did you try a different download method?
Try conducting the steps below to resolve this issue:
  1. Make sure your operating system meets the system requirements for the application you wish to install
  2. Conduct a Clean Uninstall of the previous installation & use the Microsoft Troubleshooter Tool to complete it
  3. Reboot the computer, make sure apps are not auto running in the background
  4. Log in as Administrator (check your permissions, full control) or create a new profile
  5. Temporarily disable/disconnect security features such as Antivirus, Firewall, VPN & UAC on your Windows operating system.
  6. Apply the latest Autodesk Licensing Service Update & Single Sign On Component (2020 & up).
  7. Use the Browser Download Method in your Autodesk Account or via the AVA | Autodesk Virtual Agent (download all the parts)
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 33
jesseguevara
i have the same issue. did u find a solution?
Message 5 of 33
jesseguevara
no luck. I did a clean Uninstall. I also downgraded to 2022 autodesk Lt.
I received this error attached.
Message 6 of 33
pendean
Community Legend
Community Legend
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Message 7 of 33
jesseguevara
yea i got a reply from a support ticket finally and she instructed me to do a clean uninstall and redownload autocad using the autodesk app only not the browser. it did not work.     video of the error
Message 8 of 33
mdavis22569
@d.nykiel
We you able to get this resolved ...
Mike Davis
Message 9 of 33
jesseguevara
no solution today
Message 10 of 33
bagsitjean2
Community Visitor
Community Visitor
has anyone found a solution yet?
Message 11 of 33
mdavis22569
Try reinstalling the C++ / .NET
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinst...
Mike Davis
Message 12 of 33
mdavis22569
@d.nykiel
Checking to see if any of the possible post were a solution
Mike
Mike Davis
Message 13 of 33
ntenthorey5U7LH
Has anyone found the solution to this issue?
Message 14 of 33
mdavis22569
Try the C++ /.NET reinstall I shared a couple of messages up.
Mike Davis
Message 15 of 33
ntenthorey5U7LH
Great! I repaired .Net in control panel, used the Microsoft Uninstaller Tool to Uninstall. Rebooted, reinstalled, and its working now.
Message 16 of 33
astefanovic_KP
Works for me. 💪
Message 17 of 33
d.nykiel
unfortunately in my case none of the above advice solved the problem. I have tried everything:
- repeated clean installation of AutoCAD 2023 from different sources and different language versions (interestingly in the Autodesk desktop application, I never get the option to install AutoCAD 2023. I can install all other programs like Revit, Robot etc. without any problem from the Autodesk desktop application. If I install Advance Steel 2023 from within this application it also installs AutoCAD 2023 but always with the same errors as from other sources),
- repeated reinstallation of C++ /.NET packages.
During today's attempt there were new errors when starting the freshly installed AutoCAD 2023, I add them in the appendix,
- installing AutoCAD 2023.1 update by downloading the installer from the Autodesk website.
During today's attempt, new errors have appeared when launching the freshly installed AutoCAD 2023. I add 3 in the attachments. The fourth one is "AcGe24.dll".
Does anyone know how to fix this?
Message 18 of 33
astefanovic_KP
Did you try to uninstall and after that install ALL MS Visual C++ Redistributables you have on your machine. I downloaded them through the Microsoft website.
It worked for me when I had an issue with Civil 3D 2022 installation after uninstalling Civil 3D 2021.
BTW try to avoid British/International English versions and install the English version.
Good luck 🤞
Message 19 of 33
mdavis22569
@d.nykiel  All set?
Mike Davis
Message 20 of 33
d.nykiel
Yes, I've done it before, it didn't help.
