AutoCAD 2023 run error: "pm16.dll" Module Not Found
d.nykiel
Message 1 of 33
d.nykiel
Hello everybody,
today I try to install and run new AutoCAD 2023 app. When i try run the installed app i have error wchich is schowed in attached screenschoot. On the same device I have AutoCAD 2022 app and it works fine. I have already installed AC2023 on two other devices and they work fine.
I try to reinstall this many times and install with different instalation and download options. I also tried instruction form this topic: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-...
but the error still exist.
I hope you can help me.
Replies (32)
Message 21 of 33
d.nykiel
Unfortunately, the problem is still the same.
Message 22 of 33
mdavis22569
@d.nykiel   Were you able to get this resolved?
Honestly, if you haven't at this point, I'd probably do a Windows Repair or reinstall .. something deep is probably causing this
Mike Davis
Message 23 of 33
d.nykiel
I have not been able to fix the problem. You are probably right that it is something deeper however, I don't want to reinstall Windows right now. I'm working on AutoCAD 2022 and that will have to suffice for me for now.
Message 24 of 33
mdavis22569
What about a repair install /// not a full removal?
Mike Davis
Message 25 of 33
mdavis22569
Have you put in a support ticket?
Also, you're still getting the same issue?
Are you using a deployment  for Windows and the Autodesk software?
Mike Davis
Message 26 of 33
mdavis22569
Mike Davis
Message 27 of 33
Bojan-Cabradi
Reinstalling C++ worked for me. I noticed that I had c++ 2015-2019 installed and that was replaced with latest version, which is 2015-2022. No reinstalling, no rebooting, it worked instantly.
Hope this helps.
Message 28 of 33
mdavis22569
Everyone I've been helping has been able to resolve it with the C++ / NET's.
Wondering if you have something getting added outside of Autodesk products @d.nykiel  that could be causing this.
Mike Davis
Message 29 of 33
mdavis22569
@d.nykiel
Have you been able to resolve this?
Also, if not, have you reached out Autodesk about letting maybe someone remote in and see what's going on?
Mike Davis
Message 30 of 33
mingway
You can try to download and install Microsoft Edge WebView2
https://developer.microsoft.com/en-us/microsoft-edge/webview2/
Mingway
Product Support Manager
Concord Tech Co, Ltd. 協勤資訊有限公司
LinkedIn
Message 31 of 33
d.nykiel
Hello!
Today, I have try to install AutoCAD 2023 (English) and it is finally work!
I didn't change anything, just try one more time and now there is no other problmes.
Thanks everyone for help!
Message 32 of 33
iemmadavis24
Community Visitor
Community Visitor
Maybe downloading and registering pm16.dll might help,
Hope that works, Let me know in the comment box if it does,
Emma
Message 33 of 33
anaskhan311296
Community Visitor
Community Visitor
I have uninstalled all old applications of Microsoft visual redristibutable c++ and it works
