AutoCAD 2016 is not found on this computer. [ERROR]
Message 1 of 24
Im trying to reinstall AutoCAD 2016 due to some .dll lost. I got past the "AutoCAD 2016 is already installed" puzzle, but oh boy did they fool me! There I was, happy and singing since I finally can get back to my beloved school project. When installation was half way, error message saying "AutoCAD 2016 is not found on this computer. You will need to install AutoCAD 2016 to install this product specific pack.". I've tried downloading from all three sources listed in drop-menu in download page, I've tried regedit, I've tried IObit Uninstaller, I've tried Wise Registry Cleaner, I've tried MS Fix it but no, I just cant get it to work. Can someone PLEASE help me get back to my school projects.
Im running on Win 7 x64 and the other specs are optimal. I'm trying to install AutoCAD 2016 on free Student license.
Replies (23)
Message 2 of 24
Otto
Hello Alesii and welcome to the Autodesk community!
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 24
I've tried this already, no help.
Message 4 of 24
Darin.Green
Hi Alessi,
Try the following download: AutoCAD 2016
Once the download is complete, try the installation again.
If this information was helpful, please consider using the Accept Solution
Message 5 of 24
 hello ,
are there is any progress in your problem
i think i have the same problem
Message 6 of 24
Message 7 of 24
Darin.Green
Try using the link below (Per your product):
AutoCAD 2016
AutoCAD LT 2016
Once downloaded the file should look similar to this:
Downloaded File
Message 8 of 24
Message 9 of 24
Darin.Green
Can you browse to your temp directory and post the log files. Use the following link to determine which logs to look for...
Finding the log files
Message 10 of 24
Log file as attachment.
Message 11 of 24
Darin.Green
Clear out your temp directory "C:\users\<username>\local\temp"
Check Programs & Features to see if any 2016 Autodesk products installed. If so, Uninstall them and start the installation process again from:
C:\Autodesk\AutoCAD_2016_English_Win_64bit_dlm\
Message 12 of 24
I can't seem to find "C:\users\<username>\local\temp". Where can I change the settings so that I can see the hidden folders?
I found "C:\users\<username>\AppData\local\temp" but I think that's not what you mean't?
Message 13 of 24
Darin.Green
Click Start, then type %TEMP% in the search box and hit enter. It will take you to the temp directory.
Message 14 of 24
So should I just delete everything in there?
Message 15 of 24
Darin.Green
Yes. Some things will not delete which you can choose to skip when prompted.
Message 16 of 24
The temp clearing didn't help. I get the same message saying that "AutoCAD 2016 is not found on this computer. You will need to install AutoCAD 2016 to install this product specific pack."
Message 17 of 24
Darin.Green
Did you also perform the clean uninstall, using the link I posted?
Message 18 of 24
i downloaded the pack and when i try to install it i keep getting this error service pack error.jpg
Message 19 of 24
i downloaded the pack and when i install it i keep getting this error service pack error.jpg2.jpg
Message 20 of 24
Darin.Green
Hi @Anonymous,
This looks to be an rights issue. Log onto the machine as an Administrator (Non-Restricted user), then try running the installation again.
