Authorization Error Login failed, Error -551
Moshe-A
Mentor Mentor
Message 1 of 10
Moshe-A
Hi Guys,
Have a machine (win7/64 pro) joined to domain (sbs2011) installed with AutoCAD 2015 + AutoCAD 2016
early this week i gave this machine to other user, disconnect it from the domain and rejoined it with the
the other user profile
since then the user complains: he opens his dwg files getting Authorization error (see the pic)
i would like to mention that before, this machine was working perfectly
when disconnecting the machine from the domain, the error is vanish
workaround?
thanks in advance
Moshe
Replies (9)
Message 2 of 10
Darin.Green
Recreate his Windows Profile on the machine. Before the machine was attached to the domain, the user account was local (ie. MyName) now that it's attached to the domain, it may read (ie. MyName.Domain). That being the case, you may need to remove both directories from C:\Users
If this information was helpful, please consider using the Accept Solution
Message 3 of 10
Moshe-A
Darin
No, that's not the case
the current user has no local account before joining the domain (only the previous user account is exist + 'user' account which is our default account on all machines)
lets say the user name is 'abcd' and domain name is 'Domain1.Local'
in my experiance a macine first time joining to Domain1 the OS create a profile c:\abcd
'Domain1.local' is retired and Domain2.local comes in place, the OS creates a profile c:\abcd.Domain1 (ofcours if c:\abcd still exist)
p.s: i did disconnect and rejoin it to domain but it didn't help
i also reinstall autocad and it didn't help
Moshe
Message 4 of 10
Darin.Green
Try resetting AutoCAD back to it's default settings. Use the following link to guide you through the process:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 5 of 10
Moshe-A
when i disconnect the machine from the domain the error was vanish
isn't the same autocad profile works as standalone or network member?
Message 6 of 10
Moshe-A
forgot to mension, the same error is coming from AutoCAD 2015 and AutoCAD 2016
Message 7 of 10
Moshe-A
Darin Thanks
does some one else have another idea?
Message 8 of 10
Darin.Green
@Moshe-A,
I will also ping @Mark.Lancaster & @TravisNave for their input.
While waiting for their response, try resetting your Autodesk login files on your system using the following workflow...
  1. On your computer, navigate to:
    • ​​C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to
    • C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
When you start the application, it will Prompt you to choose one of the following:
  • Login - 30 day trial licenses
  • Serial Number - Standalone and Single-User activations
  • Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.
NOTE: Students will always use the Serial Number option
Message 9 of 10
Moshe-A
Darin,
Mean while the CEO changed his mind and decide to transfer these licenses to another machine
i have already done that, so i even can not try this solusion.
Next time...
at least some thing good this forum gained, a similar theard could be found untill now.
Thanks you very much
Moshe
Message 10 of 10
natasha.l
Hello @Moshe-A,
Thank you for reporting back and being a part of the community. Smiley Happy
