Application installation problems
Regards.
I have downloaded SketchBook for teachers. I have followed all the steps for activation but I am experiencing problems and I get the following message in a box "SketchBook.exe-Application error. The application could not start correctly (0x000007b)". The previous process I have done several times and the same box appears.
My computer is windows 7 professional, 64 bits
Thank you.
vahn.chua
Autodesk Support
Autodesk Support
@Anonymous
Welcome to Autodesk Community.
It could be caused by a corrupted installation.
Have you tried to follow these steps provided in this Knowledge Base article?
"The application was unable to start correctly (0xc000007b)" when launching Autodesk products
Vahn Chua
Hello
I select the accept button and I did not find the problem.
vahn.chua
Autodesk Support
Autodesk Support
@Anonymous
Hi I think you misunderstood the 'Accept as Solution' button idea, just ignore that.
You need to refer to the hyperlink for some steps to follow:
Vahn Chua
