activation problem
activation problem
phil9LCTX
Message 1 of 14
activation problem
phil9LCTX
i purchased revit lt suite for myself installed on laptop
purchased revit lt for my drafter
became account manager and assigned revit lt to drafter he installed w no issue
i read i can install a second copy and just sign in to use it.  so for my self tried to install revit suite on my home pc and will not activate.   leaves me w option to sign in as a different user and has serial number and product code for the copy i purchased for my drafter(wont let me change  sn and pc).
messed around with assignments with no result.
do i need to create another user for myself under different email and assign the copy to myself?
please help
Replies (13)
Message 2 of 14
Mark.Lancaster
@phil9LCTX
Welcome to the community..
It sounds like you used the wrong serial number when installing your product.   When you launched the product for the first time on your home machine, did you get the lets get started dialog that prompted you to either select the serial #/product key or to use a network license?
Go to the C:\ProgramData\Autodesk\CLM\LGS folder on your home machine and tell us what sub-folders that are in there.
Mark Lancaster
Message 3 of 14
phil9LCTX
mark, thanks for the prompt reply.
lt contains sub folders for both revit lt copies I purchased. the 843i1 which is for the suite and the 828i1 for the non suite.
I would like to use my copy on this machine which is the 843i1. does it automatically go to the first folder? shall I delete the folder for the version I don't want to use?
thanks
phil
Message 4 of 14
Mark.Lancaster
@phil9LCTX
First make sure none of the Autodesk products are running on your home machine.  In those 2 sub-folders delete the LGS.data.  Then launch your product again and it should prompt you "Lets Get Started".  Select enter serial # and product key and use the correct serial # this time.
Mark Lancaster
Message 5 of 14
phil9LCTX
thanks,
I deleted the content of the two sub folders. then launched the program.
this gets me back to the enter serial # dialog, however, the serial number and product key for the copy I don't want is already in there. I can change the serial number but the product key cannot be changed to the corresponding serial number
do I need to delete the subfolder for the unwanted copy? and not just the date within.
phil
Message 6 of 14
Darin.Green
You probably installed Revit and not Revit LT. In this case you will need to uninstall Revit and Install Revit LT. You can download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, one they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Message 7 of 14
Darin.Green
By the way what product key are you using?
Message 8 of 14
phil9LCTX
I don't think I installed the full version. I followed link from the my products page
this is for the suite this is the one I want to use for myself........the key for the non suite appears in the box that I cannot change
I have removed the serial number from your post. Please, do not post your product serial number on public websites and forums such as this one.I don't think I installed the full version. I followed link from the my products page
Message 9 of 14
Mark.Lancaster
@phil9LCTX
You just committed one of the worse thing you can do on this forum...  Smiley Sad  Posting person information such as your serial #.  Don't do that...
Mark Lancaster
Message 10 of 14
phil9LCTX
I thought we where on a private email now. pls delete post
Message 11 of 14
Mark.Lancaster
@phil9LCTX
No this is a world wide public user forum..  We are unable to delete any postings because we are only users like you.  Anyhow I have already notified the moderator to remove your personal information (so it can be protected).
I don't know why you can't change the serial # information at this point in the Let's Get Started dialog...
Might suggest uninstalling the product from this machine and perform a clean uninstall per these instructions.  Then install using your Revit LT Suite installation.
Mark Lancaster
Message 12 of 14
phil9LCTX
10 4 thanks will try clean istall.
Message 13 of 14
Darin.Green
@phil9LCTX, you are correct. Your serial numbers are valid for your products. However, you probably installed Revit LT from wrong install media. This is the only reason you're not able to activate it.
Uninstall Revit LT from that machine and make sure you're installing the correct package
  • Autodesk AutoCAD Revit LT Suite 2017 W/ Product Key: 834I1
  • Autodesk Revit LT 2017 W/ Product Key: 828I1
Message 14 of 14
phil9LCTX
clean install worked.. thanks so much.
