3DS Max 2018 will not open or show any signs of launching
Message 1 of 21
So I've just recently gotten the month long trial of 3DS Max and I've installed it via the Autodesk Desktop App.After the install, clicking launch will cause the cursor to momentarily switch to the loading cursor, and after a few seconds, switch back. No windows open, nothing. The app simply won't launch.
Replies (20)
Message 2 of 21
Otto
Hello shawnbasnett and welcome to the Autodesk community!
It looks like you're experiencing issues with launching your product. The following link(s) should help you resolve the problem:
Troubleshooting why a program does not open
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 21
I imagine this is a bot, but in the event that it isn't, none of the solutions given there seem to have solved my issue.
Message 4 of 21
mdavis22569
@Anonymous
Otto is a bot ...
So does it show up at all in the task manager?
Quick question: What .NET Framework are you currently using:
https://docs.microsoft.com/en-us/dotnet/framework/migration-guide/how-to-determine-which-versions-ar...
Mike Davis
Message 5 of 21
No, it doesn't appear in task manager when i attempt to launch it, there doesn't seem to be a process for it either.
I have all the way up until 4.0 installed.
Message 6 of 21
mdavis22569
Depending on your OS you probably need to upgrade it
at least to 4.5 if not 4.6.2
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Mike Davis
Message 7 of 21
I've just updated my .NET and now the splash screen does open, but only for like a split second, still nothing in the task manager.
Message 8 of 21
I am experiencing exactly same issue. Splash shows up for split second and that is it.
Happens on 3ds max 2017 and 2018.
I am running on windows 10, from regedit i found out i have .Net Framework version 4.7.02046. I am not able to uninstall latest .Net framework and reinstalling windows is not in question.
I also tried clean reinstall and the issue is the same.
Message 9 of 21
natasha.l
Hello @Anonymous & @Anonymous,
Please make sure to review this post Windows 7, 8.1, 10 Updates | Microsoft .NET Framework.
1. Depending on the OS you will uninstall .NET Framework 4.7 by itself or uninstall the update altogether.
2. Then, install the .NET Framework required to run the software.
 .NET Framework 4.6.2  for 3ds Max 2017
or
 .NET Framework 4.0  & .NET Framework 4.6.2 for 3ds Max 2018
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Message 10 of 21
natasha.l
Also, review the system requirements, check the Visual C ++ to download for your Operating System : SDK Requirements
Message 11 of 21
Hello @natasha.l,
I followed link you've provided. I have windows 10 home 64-bit and the link suggests in that case to remove KB3186568. But i don't have it installed.
I've attached mine installed updates in attachments.
Do i overlook something or is there some other way?
I also tried "Turn Windows features on or off" with no success ..
Edit: 3ds Max 2017 worked before so i suppose my system meets hardware and software requirements.
Message 12 of 21
natasha.l
Hello @Anonymous,
I see you have the Windows 10 Creators 1703 (KB4022405) update installed.
  1. Please try uninstalling this update
  2. Make sure you install the proper .NET Framework.
or
 3. Then, Check/Edit the registry to run the proper .NET version
 4. You can try to run the product or uninstall/reinstall the product after fixing these issues
Please let us know how it goes. Smiley Happy
Message 13 of 21
I've followed your instructions, but i'm still having the same issues. My installed updates are below as well.
Message 14 of 21
Hello @natasha.l,
I can't uninstall Windows 10 Creators 1703 (KB4022405), when i right-click there is no context menu. Looks like it is forbidden by Microsoft.
I tried to use restore point but it looks like it is too late. Please see attached picture of my System Restore Dialog.
Any other hotfix or patch comming?
Message 15 of 21
natasha.l
Hello @Anonymous,
Let's try the steps without uninstalling the update then, try installing the .NET Framework below.
1. Install the corresponding .NET Framework for 3ds Max 2017
2. Edit the registry to change the system's .NET version 4.6.2
Thank you for posting. Smiley Happy
Message 16 of 21
Hello @natasha.l,
- I am not able to install previous versions of .Net Framework, please see attached picture
- I managed to change the value, i had to add Full Permissions for myself
- I have tried 4.5 value, .Net 4.6.2 installer failed, 3ds MAX didn't start
- I have also tried 4.6.2 value with same results
- I did the reister change for all 4 register directories:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client\1033
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\1033
I doesn't look like that the register change helped in any way ..
Any other ideas I could try? Can I send you any log or something else?
Thank you for your help.
Message 17 of 21
natasha.l
Hello @Anonymous,
Try download the installation executable from the following link to download AIDA the logs collected will help gather & troubleshoot installation errors for you.
Message 18 of 21
Hello @natasha.l,
here are the logs. I hope I understood what you need me to do.
Thanks.
Message 19 of 21
Here is program output, i missed it yesterday. Smiley Happy
Message 20 of 21
natasha.l
Hello @Anonymous,
Here is some Microsoft information on how to disable Defenders on a Windows 10 on the Defender Security Center app in my post: Windows 10 Creators Update & Defender. Try that to see if that is the real issue. Also try to find out from Microsoft how you can remove this update.
Thank you for posting & best of luck. Smiley Happy
