3ds max 2015 installation failed !
Message 1 of 9
Can someone help me fix this..
Replies (8)
Message 2 of 9
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Could you post your log file? It is most likely an issue with installing on Windows 10. Have you tried disabling your antivirus and installing from the virtual agent.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 3 of 9
2016/1/25:18:36:29 Tricia ANTIPOLO === Setup started on ANTIPOLO by Tricia ===
2016/1/25:18:36:29 Tricia ANTIPOLO Path_Length: 155
2016/1/25:18:36:29 Tricia ANTIPOLO Current Directory C:\Users\Tricia\AppData\Local\Temp\_AIA2DC.tmp
2016/1/25:18:36:29 Tricia ANTIPOLO Launch
2016/1/25:18:36:30 Tricia ANTIPOLO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/SETUP_x...
2016/1/25:18:36:31 Tricia ANTIPOLO PageOpen LaunchDialog
2016/1/25:18:36:38 Tricia ANTIPOLO PageOpen LicenseDialog
2016/1/25:18:36:38 Tricia ANTIPOLO PageOpen ProductInfoDialog
2016/1/25:18:36:38 Tricia ANTIPOLO PageOpen ProductSelectionDialog2
2016/1/25:18:36:42 Tricia ANTIPOLO PageOpen FullProgressDialog
2016/1/25:18:36:42 Tricia ANTIPOLO Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2016/1/25:18:36:42 Tricia ANTIPOLO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/1/25:18:37:09 Tricia ANTIPOLO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/1/25:18:37:10 Tricia ANTIPOLO Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/VCREDIS...
2016/1/25:18:37:10 Tricia ANTIPOLO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/1/25:18:38:08 Tricia ANTIPOLO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/1/25:18:38:09 Tricia ANTIPOLO Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/DIRECTX...
2016/1/25:18:38:09 Tricia ANTIPOLO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2016/1/25:18:40:45 Tricia ANTIPOLO Install DirectX® Runtime Succeeded
2016/1/25:18:40:45 Tricia ANTIPOLO Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CM.tar....
2016/1/25:18:40:45 Tricia ANTIPOLO Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0364-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/25:18:41:11 Tricia ANTIPOLO Install Autodesk® Material Library 2015 Succeeded
2016/1/25:18:41:11 Tricia ANTIPOLO Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILB.t...
2016/1/25:18:41:11 Tricia ANTIPOLO Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0364-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/25:18:41:30 Tricia ANTIPOLO Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/1/25:18:41:32 Tricia ANTIPOLO Download Skipped CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/CMILM.t...
2016/1/25:18:41:32 Tricia ANTIPOLO Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0364-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/25:18:42:18 Tricia ANTIPOLO Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2016/1/25:18:42:46 Tricia ANTIPOLO Download Play MAX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/MAX.tar...
2016/1/25:18:43:04 Tricia ANTIPOLO Download Error MAX <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/MAX.tar...
2016/1/25:18:43:04 Tricia ANTIPOLO Download Aborted MAX http://edutrial.autodesk.com/SWDLDNET4/2015/MAXDES/WI/{4AB52C7E-5B8B-4D96-B044-F587EC2DE1E3}/MAX.tar...
2016/1/25:18:43:04 Tricia ANTIPOLO Install Autodesk® 3ds Max Design 2015 Failed Download Failed, Installation aborted, Result=1603
2016/1/25:18:43:22 Tricia ANTIPOLO Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2016/1/25:18:43:37 Tricia ANTIPOLO Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2016/1/25:18:43:57 Tricia ANTIPOLO Rollback Autodesk® Material Library 2015 Succeeded
2016/1/25:18:43:57 Tricia ANTIPOLO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/1/25:18:43:57 Tricia ANTIPOLO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/1/25:18:43:57 Tricia ANTIPOLO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Message 4 of 9
matthew.d
Hi @Anonymous,
Looks like it is this: Install Autodesk® 3ds Max Design 2015 Failed Download Failed, Installation aborted, Result=1603
Did you try the virtual agent linked above.
Matt DiMichele
Message 5 of 9
not yet, but i will try.
Message 6 of 9
i tried but it says file corrupted error!
Message 7 of 9
jeffrey.sin
Hi @Anonymous,
I tried just now to download from the Virtual Agent and install 3ds Max 2015 using that and it went well. Perhaps you can try again using this link
Thank you,
Jeffrey Sin
Autodesk Customer Support
Message 8 of 9
Message 9 of 9
jeffrey.sin
Hi @Anonymous,
Thank you for the information provided. I had to edit your post to remove your screenshot as it showed your serial number there, which is a private and confidential information that shouldn't be posted on a public forum.
In any case, the reason for the error is that your license entitlement is for Autodesk 3ds Max Design 2015 while what you have installed is Autodesk 3ds Max 2015. Kindly visit the Virtual Agent once again and download Autodesk 3ds Max Design 2015 installer instead.
Alternatively, you can also go back to the Education Community site to obtain a serial number for Autodesk 3ds Max 2015 and use that to activate your currently installed software.
Let us know how it goes. Thank you,
Jeffrey Sin
