RAIL DESIGN JUCTIONS AND TURNOUTS
Its impossible create juctions and turnouts in railway (components road) and the cross section is inccorect.aparato de via.JPG
3 Comments
hola cual version de infraworks es la que viene con la herramienta de seccion transversal ? slds
Hola buenos dias, creoq eu fue a partir de la version 2018, lo unico es que este tipo de seccion que yo reprensetado es un poco falsa, luego hay que retocarla con Civil 3d.
Un saludo
pieter_haeck
Would be interesting since with styled rail functionality, you cannot specify radii while designing. This can be doen with component roads en applying custom assemblies, but then you have bad intersections (turnouts,...). Would be great since C3D (rail) corridors are now possible to import in Infraworks.
Unless I'm missing something 🙂
Greetings
Pieter
