PURGE/VACUUM Tool for down model to reasonable size
The ability to reduce file size of infraworks model or keep the sqlite database in minimal size using purge or vacuum tool. Since SQLite database file may get larger and larger as time goes by. Even if the data is deleted from the database, the database file will not be shrunk. Infraworks need this tool immediately..
Damayanti
10 Comments
KPerison
I entirely agree with this !! Model gets very bloated very quickly.
KPerison
The model size balloons out of control very quickly.  When data is removed from model the size of the database does not get any smaller.
ramesh_sridharan
KPerison, Can you provide some information on what type of data (or data sources) you are working with?
@ramesh_sridharan in my case that's happened when I used fbx file. My fbx huge and detail (some above 500 mb). After deleting the old fbx and reimport the new fbx (because of design changes) infraworks model always getting bigger and bigger. Even deleting all fbx file size not reduced
scheel
The Purging/vacuum-Tool should not only purging the sqlite database.
More imoirtant are the files section.
I have import some caniddates of a big ECW-image of more the 2 GB each and release them after a moment.
My model grown to more the 7 GB in moments in the files section. Duplicate the model didn't solve the problem
it copy also the unneeded/released data.
Thorsten
Eric_Chappell
Does the current way that InfraWorks 360 handles the cache meet your needs to keep the model size smaller?  What I mean is that the surface tile cache location is separate from the sqlite file and corresponding folder:
scheel
No, this doesn't meet our needs. The model size is stil growing but then split in different directories.
And during copy the model it still copy all file, also the files still not needed.
Same with proposals or testing with bigger 3d-parts or Images.
Thorsten
Eric_Chappell
Our product team is reviewing this internally.  Stay tuned.
Raghavendra_Bhat
Have some kind of cleanup tool that will remove the unwanted data from the are that has been cropped off will be of good help.
neilyj666
Any movement on this topic - nearly 6 years under review?
