Pipelines and connectors
Can there be some additional attributes made available to the pipelines and connectors:
Lid Level
Invert Level
Outlet Level
Sump Level
These are commonly used in New Zealand.
4 Comments
Status changed to: Archived
Drainage Design for InfraWorks 360 provides this level of functionality for drainage networks today.
The generic pipelines and connectors have sufficient generic functionality that that can represent items that don't have these common elements - for example - a surface pipeline.
Thanks for replying.
Sorry I don't think I explained myself very clearly. I'm referring more to importing GIS or survey data for existing/as-built drainage services. Admittedly the quality of the information that is received from the service providers isn't that great, a lot of attributed information is left out.
The information that would normally be provided are:
Type
MH Diameter
Pipe Diameter
Lid Level
Sump level
MH Depth
Length
Invert level
Outlet level
I guess what I am having trouble with is assigning an invert and outlet level to the ends of pipes, if I use elevation offset then I think that is assuming a depth from surface level rather than using an elevation level?
The depth from surface isn't usually supplied for pipes in GIS or Survey data here in New Zealand.
Best regards
James Holloway
Senior AEC Account Manager
[cid:image001.jpg@01D09866.96A61FA0]<>
CADPRO Systems Ltd<>
Phone: +64 9 302 4028
Mobile: +64 274 820 846
Email: james.h@cadpro.co.nz<>
Auckland - Level 1, 527b Rosebank Road, Avondale
Christchurch - Unit 3, 162 Kendal Avenue, Russley
New Zealand
Autodesk Gold Partner
Architecture, Engineering & Construction
Engineering, Natural Resources and Infrastructure
Manufacturing
Specialisation: Building - Advanced MEP - Civil Infrastructure - Product Design & Manufacturing - Process & Power
Value Added Services: Consulting Specialised - Product Support Specialised - Authorised Developer - Authorised Training Centre - Authorised Certification Centre
HP Preferred Partner
Useful Links for our Autodesk Subscription Customers:
Subscription Management<>
How to obtain media pack (DVD/USB Drive) for your last Subscription upgrade<>
How to transfer a Standalone License from one PC to another<>
How to find your Serial Number and Product Key in Autodesk Account<>
How to download Software from Autodesk Account - Install Now Method<>
How to download Software from Autodesk Account - Browser Download Method<>
James -
InfraWorks is expecting the geometry of the data to control the pipe ends rather than the data.  Can you email me and we can discuss further?
Matt Anderson
Product Manager
matt.anderson@autodesk.com
Changing this from Solution Provided to Under Review.  The Clarifying comments indicated that getting values from non-3d geometry pipes is an known gap.
Rail Community
