Import data straight away from dwg
Some releases ago there was a dwg import.
The dwg import right now converts the dwg to an image.
Would be great to be able to import lines, points from a structured dwg again as there was in the past.
1 Comment
Matt__W
Be sure you're using the correct DWG import option as there are now 3 in the 2017 version:
  • AutoCAD Civil 3D DWG
  • AutoCAD DWG (3D Objects)
  • AutoCAD DWG as 2D Overlay
It sounds like you should be using the Civil 3D import option.
