When do we get full 4K UHD support in IW? AutoCAD 2018 is already fully supported on 4K so I guess IW can't stay behind?
I noticed the current UI has problems of not correctly scaling text and menus with 4K UHD resolution (3.840 bij 2.160 pixels). These high resolutions are becoming more available and will probably become the 'standard' within 2 years.
For now, I can work around the problem using Windows 10 text scaling or disabling DPI scalability in the Application Compatibility Settings. However, the menu dropdowns from the Utility bar are not supported using the last workaround.
