Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
4K UHD UI support
4K UHD UI support
When do we get full 4K UHD support in IW? AutoCAD 2018 is already fully supported on 4K so I guess IW can't stay behind?
I noticed the current UI has problems of not correctly scaling text and menus with 4K UHD resolution (3.840 bij 2.160 pixels). These high resolutions are becoming more available and will probably become the 'standard' within 2 years.
For now, I can work around the problem using Windows 10 text scaling or disabling DPI scalability in the Application Compatibility Settings. However, the menu dropdowns from the Utility bar are not supported using the last workaround.
4 Comments
C3D_TomR
I’m definitely adding my support to this one. Thanks for posting, @Anonymous.
f_furger
It's 2019 and nothing's happened yet! Please hurry up now!
ramesh_sridharan
This feature is implemented and planned to roll out with the upcoming IW 2021 release. Here are some before and after samples.IW Canvas View - BeforeIW Canvas View - BeforeIW Home Screen - BeforeIW Home Screen - BeforeIW Canvas View - AfterIW Canvas View - AfterIW Home Screen - AfterIW Home Screen - After
Good!
