Video Creation
Video Creation
Message 1 of 11
Video Creation
Dear expert:
I have a question about create the video about my infraworks case.
I want to make a video which include different cases. Do the software have this kind of function?
Replies (10)
Message 2 of 11
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
do you want to create a video that shows what you are doing in InfraWorks?
If yes, then use Screencast.
Do you want to create a story board and render a video showing different proposals?
Rendering a video is possible from the story board, but only for one proposal at a time.
See also: InfraWorks Help: About Storyboards
Karsten.
Karsten Saenger
Message 3 of 11
THANKS Karsten.
That you answered my question. Now I used story board to create a video.
I hope the video can show the infrastructures before using and using( eg. have some cars or ships).
Should I use some other softwares to make my story idea come true?
Message 4 of 11
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
I cannot give you any recommendation which tool to use. It depends on the workflow and final outcome.
In any case, you can always create several videos in InfraWorks and use these in a separate video composing tool to blend/merge, for example if you want to show proposal A and late proposal B in one video.
Karsten.
Karsten Saenger
Message 5 of 11
JasonArtley
I use Windows Movie Maker (free!) to combine/edit the videos exported from Infraworks. It's simple to use and produces great results.
If you have Windows 10, here is the link for download: https://www.microsoft.com/en-us/p/movie-maker-10-free/9mvfq4lmz6c9
Message 6 of 11
OK, I get it.
I will try to make some videos which I want to use in infraworks.
Thanks for your helpMan Very Happy
Message 7 of 11
Thanks for your suggestion.
But I dont have the window 10.
I will try to find other software to help me.
Message 8 of 11
paulypage3
Community Visitor
Community Visitor
yes, Vn mod apk is best for this. it has all the functions you need. you should try this.
Message 9 of 11
nikowi5445
Community Visitor
Community Visitor
Yes, Autodesk InfraWorks allows you to create videos that showcase different project scenarios. You can use the Storyboards feature to record various design alternatives, perspectives, and animations within a single video.
To do this:
  1. Set Up Your Views – Navigate to different viewpoints and scenarios in InfraWorks.
  2. Create a Storyboard – Use the Storyboard Creator to add multiple clips representing each case.
  3. Adjust Transitions & Effects – Customize camera angles, animation speed, and visual settings.
  4. Export the Video – Once finalized, export the video in your preferred format for presentations or sharing.
If you're working with photo or video editing, tools like Adobe Lightroom can enhance visuals before integrating them into InfraWorks. Check out Lightroom Modded APKs for premium Lightroom features that help optimize images for professional presentations
Message 10 of 11
kinzaishfaq070
Community Visitor
Community Visitor
Yes, InfraWorks allows you to create a video that includes multiple design cases or scenarios. Here's how you can do it:
  1. Open your InfraWorks model.
  2. Use the Storyboard tool to create a new animation.
  3. Add different camera views or clips for each case or scenario.
  4. You can switch between proposals (design alternatives) and record each one in a separate clip.
  5. Arrange all clips in the storyboard timeline to create a single continuous video.
  6. Export the final video using the Export to Video option.
This way, you can show multiple cases in one video.
Message 11 of 11
johnrobert78677
Community Visitor
Community Visitor
In Autodesk InfraWorks, you can create one video showing multiple cases by using the Storyboard feature. Set up each case as a separate proposal, create animation bookmarks for each, and add them to the storyboard in sequence. Switch proposals between shots, then export the storyboard to produce a single video that seamlessly includes all your different cases.
vist for more details: pojavlauncher apk
