InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Unable to Open Model from Model Builder
5 REPLIES 5
darrenr
599 Views, 5 Replies
Hi, I just tried creating new models with the Model Builder. Once it's done and I try to open it, It asks me where would you like to store the model? Autodesk Docs or Local. I have tried both and then it says Unable to Open Model. See attached screenshots. All my other models open fine, it's just the ones I create from Model Builder. Any help would be greatly appreciated.
Darren
5 REPLIES 5
Karsten.Saenger
in reply to: darrenr
Hi @darrenr ,
most times the reason for the issue is that the git part of the model database cannot be created on your local computer.
There are a number of reasons, why this can happen. Can you send the latest InfraWorks log files from path %AppData%\Roaming\Autodesk\Autodesk InfraWorks\logs ?
Karsten
Karsten Saenger
darrenr
in reply to: Karsten.Saenger
Hi Karsten and thanks for the reply. I have recently got a couple error message when I open Infraworks as well which I have attached. Not sure if they have something to do with it. I had ignored them because everything in my previous models seemed to work ok.
Darren
Karsten.Saenger
Hi @darrenr ,
thank you for sending the information.
The error message I can see is:
Git exit code: 128
Git output: Cloning into '.'...
error: bogus format in GIT_CONFIG_PARAMETERS
fatal: unable to parse command-line config
error: Service Exception: Failed to clone the remote feature repository.
There are two possible reasons for such errors:
  1. OneDrive (any cloud drive) or a server is used for the InfraWorks models. I can see a Z:\ drive - can you say what sort of drive that is? If it's a mapped cloud or server drive, then change the paths for InfraWorks models to a local drive. More info: https://knowledge.autodesk.com/article/Error-Unable-to-Open-Model-in-InfraWorks
  2. Installation error. A clean reinstallation of InfraWorks might solve the issue. I suggest upgrading to InfraWorks 2023.1 if possible. See also: https://knowledge.autodesk.com/article/Clean-reinstallation-of-InfraWorks
Best Regards,
Karsten.
Karsten Saenger
darrenr
Thanks for your help. I uninstalled Infraworks which was a total pain. It kept telling me it was still on the machine. I had to go through and remove any leftover Infraworks folders and finally go into the registry and remove it and then it let me re-install. And finally now it lets me open the model builder project I created. What a pain. Thanks again.
I have similar problem with Infraworks 2023.
I can create a model using New>Create Model
But when I try to create a model using Model Builder I get the same error "Unable to Open Model".
I have reinstalled Infraworks and also had an agent trying to help but I am still getting the same error.
Solution was to avoid OneDrive, which I did and have update Registry to point to a local C: drive
Please help
Rail Community
