1.How to add new types of vehicle and their 3D model in to traffic and mobility simulation?
2.How to calibration of model in traffic and mobility simulation?
3.How to control speed of each type of vehicle and each lane respectively?
4. How to input vehicle routing decision?
Solved by Karsten.Saenger. Go to Solution.
Hi @Anonymous ,
the flexibility you are looking for is only available in the Traffic/Mobility Simualtion panel.
Please take a look at the help files from the application to learn how it works exactly.
Unfortunately, the results of simulations and animations will not be availabe in the InfraWorks model.
Karsten.
Hello @anil3KT3J, select under InfraWorks > Analyze > Mobility Simulation and then define the area of simulation.
Inside of Mobility Simulation , select Validation > Validator. Here is where you calibrate the model for Mid-Block Counts, Turn Counts, O/D Counts, Stand Counts, Screen Line Counts, Trail Counts, Traverse Counts, Trail Times and Traverse Times.
Thank you very much,
Edmundo Herrera, P.E.
Hi @Anonymous ,
the help PDF's are located under C:\Program Files\Autodesk\InfraWorks\TrafficAnalyst\help .
But you can also open them from within the Traffic/Mobility Analyst panels.
Karsten.
