TIFF DATA ISSUE IN IW
Message 1 of 17
Hello everyone,
I have a question about TIFF data. So i've created new surface (TIFF data) in Autocad 3D Map, now im trying to insert this TIFF data to IW360. As im inserting it to IW model, it makes my IW Model invisible when i delerT this TIFF surface from IW, my model comes back
Any Idea about?
Just would like to menion that, ive checked coordinates, so all is correct.
Replies (16)
Message 2 of 17
tmachado
Hi @Anonymous, can you share the tiff image? and upload a screenshot of what you are experiencing.
It could be a video driver issue.
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Message 3 of 17
Todd_Rogers
Right-click on the tif image in your Data Connections and choose Configure. Once in the dialog box, click the Raster tab. Pick the ellipsis for Color Masking. Choose the color white, or you can use the color picker option.
Todd Rogers
Civil Administration
Message 4 of 17
Thanks for the answer
here is the screen shots
1) TIFF Image
2) IW model before and after TIFF data import
Message 5 of 17
Hallo
Ive tried that methos but as you can see from the screen shot that, there is grayscale and no more options are available
Message 6 of 17
tmachado
Hi @Anonymous, not too sure what the first file should be showing I just see a white image...???
But I noticed on the data configuration image that you uploaded that the image is configured as ground or terrain.
Can you delete that and inserted again making sure that it gets configures as Ground Image...
Tatiana Machado
Message 7 of 17
Thank you so much foryour help Tatiana
Just noticed that the options are not anable in my confiquration window
Message 8 of 17
tmachado
Is that  Geo Tiff?
Can you share the image?
Tatiana Machado
Message 9 of 17
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous,
do you have any more information about the tiff meta data (number of bands, bits)?
It could be that the image just has more bands or bit depth than InfraWorks can handle.
Karsten.
Karsten Saenger
Message 10 of 17
Hello
yes it is just white polygon
Message 11 of 17
roskirko
One aspect of your Geotiff are the unusual bounding coordinates.
The Easting value is much larger (in metres) than that which is possible in Zone 32.
Where on earth is this?
Geographic Information Systems
Fanshawe College
Message 12 of 17
Dear Roskirko,
Thanks for your reply.
The surface is in the south of Germany, UTM N32. Just id like to ask wich program did you use to check TIFF image coordinates
Message 13 of 17
tmachado
Hi @Anonymous, thank for the file, this is what I get in Map
Those are the coordinates that the file has, I am trying to create an IW model but this is a big file, so is taking a little be to process...
Tatiana Machado
Message 14 of 17
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous,
your Tiff file is a raster terrain/surface.
The problem is that it has cooridnates in long ETRS89 notation, means there is a leading 32 (Mio.)
Autodesk programs always use the short notation.
Your solution is to create a custom coordinate system in Map/Civil 3D that deals with the long notation.
Check this page for a description of how to do that:
http://geospatialnavigator.typepad.com/geospatial_navigator/2011/10/automatische-transformation-von-...
Alternatively, move your image: x = -32000000.
Karsten.
Karsten Saenger
Message 15 of 17
Thanks For th reply Dear Saenger
Just would like to write that, i cretaed this TIFF image in AutoCAD 3D MAP. so probably i did mistake on coordinate System or GRID Map
Thank you so much
King Regards
Kamal Mammadov
Message 16 of 17
tmachado
That could explain why I could not make this match with any CCS and the GEO location map
Tatiana Machado
Message 17 of 17
roskirko
I converted the file coordinates and named it SG1Clip.tif. It seems to work in Infraworks 2018 as a terrain data source using a User Coordinate System of UTM84 32N. I used PCI Geomatica 2017 for the conversion.
Fanshawe College
