pointcloud data to 2D or 3D objects
No aplicable
1.209 Vistas
5 Respuestas
Mensaje 1 de 6
No aplicable
hello,
I am processing a pointcloud captured from a Faro scanner in Recap, then opening the recap file in autocad and manually sketching over the features to create 2D environments based on the pointcloud data. Is there a software that will translate pointcloud data into a 2D or 3D format automatically? I have read about Autodesk Infraworks potentially being able to do that, but I would need the files to be viewable in autocad.
Thanks in advance.
0 Me gusta
Soluciones aceptadas (1)
1.210 Vistas
5 Respuestas
Respuestas (5)
Mensaje 2 de 6
Alfred.NESWADBA
Solución aceptada
This can be done with AutoCAD as long as you need 2D sections from the pointcloud.
Here you find some information about pointcloud in AutoCAD >>>click<<<
If you need 3D objects like curb or linemarking converted to 3D objects (later in Civil 3D ==> Feature Lines) then yes, then Infraworks might be the product of choice.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
Mensaje 3 de 6
No aplicable
Thanks for the info Alfred.
When I use the command PCEXTRACTSECTION I am shown a "section object not found" upon selecting my pointcloud. Any ideas why?
Thanks again.
0 Me gusta
Mensaje 4 de 6
Alfred.NESWADBA
Did you first create a section object and then start the command?
- alfred -
[Edit] video attached, not beautiful, but shows functions [/EDIT]
Alfred NESWADBA
0 Me gusta
Mensaje 5 de 6
No aplicable
Got it now. Thanks!
0 Me gusta
Mensaje 6 de 6
No aplicable
Whenever I delete a section and create a new one, it is not possible to extract section lines anymore.
It displays: "section object not found"
Any solutions?
0 Me gusta
