CityGML import
CityGML import
CityGML import
When I use FME Quick Translator to convert CityGML file to IMX, I get this error. How can I fix it?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
in the other forum post I used test data from German authorities (https://forums.autodesk.com/t5/infraworks-forum/citygml-import/m-p/7775739#M13164 -- https://www.ldbv.bayern.de/service/testdaten.html). Have you tried with this test data and does it work?
Karsten
Karsten Saenger
It worked.
For me the quick translator would not run a CityGML file but the normal FME desktop did a normal translation to IMX and it worked wonderfully. This happened on three of our CityGML test models, so the quick translator just might not work.
One suggestion is to get FME trial and see if it works there. For me it did.
