Boa tarde,
Criei um modelo no Infraworks, porém quando o abri no C3D, apareceu apenas o alinhamento e as superficies, porém o perfil do terreno e o de projeto que eu havia criado no Infraworks, não foram criados, implicando em retrabalho no C3D. Como corrigir isto? As configurações de em quais layers cada coisa que virá do Infraworks deverá ficar no C3D estão configuradas.
Solved by Eduardo.Soethe. Go to Solution.
Hello @Anonymous,
I assume with profile you mean the road profile you created with design roads in InfarWorks.
After the import in Civil 3D, have you checked the Centerline Alignments for existing profiles. You will need to create a profile view if you want to see them in Civil 3D.
Please double check these help content for information what kind of objects can be imported into Civil 3D from InfraWorks:
AutoCAD Civil 3D Help: About Exchanging Data Between AutoCAD Civil 3D and Autodesk InfraWorks 360
You might also need to edit your configuration file used for the import:
AutoCAD Civil 3D Help: To Configure Autodesk InfraWorks 360 - AutoCAD Civil 3D Exchange Settings
Karsten.
How are you importing the data from Infraworks to Civil 3D? Are you using the OPEN INFRAWORKS 360 MODEL command?
See the Screencast below for more info.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Or are you exporting from Infraworks to IMX format and then importing that into Civil 3D? (see Screencast below) or are you doing something different?
Matt Wunch
Twitter | LinkedIn
@Anonymous bom dia.
Entendo o seu problema, vamos lá!
No meu caso esta dando tudo certo na importação.
Tenho perfil no Infraworks e estou importando no Civil e o mesmo vem para o Civil 3D
Veja o vídeo abaixo, caso tenha feito algo diferente tente desta forma!
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
