Only Part of Civil3d surface importing
ralstogj
ralstogj
Hi
Just getting into infraworks and have import a composite finished surface and only half shows up. An exisiting ground surface from another file dispalys ok. Any suggestions why.half_roundabout.png
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
elliott.rosenfeld
I can't say for sure, but perhaps your coordinate systems is experiencing a metric-imperial conversion issue. You can read this recent forum thread for help with troubleshooting coordinate systems http://forums.autodesk.com/t5/infraworks-general-discussion/add-a-fbx-file-to-infraworks-corrdinate-....
Could you provide some more explanation of your process?
What is the existing ground surface file?
What type of file is the composite finished surface?
Does your model have a terrain layer?
Thanks!
Elliott
Principal Specialist, Infrastructure
BrianHailey
If you can share the surface file, that would probably be the best so we can test it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
ralstogj
All
i noticed that when I turned my existing ground surface layer back on in the infraworks model both the existing and all of the proposed ground show up in the area that they over lap. So must be something to do with the layers in infraworks which I do not fully understand yet.
Regards
[airey]
Justin Ralston
Senior Engineer - Manager Queenstown
AIREY CONSULTANTS LTD
P.O.Box 2069, Wakatipu, Queenstown, 9349? Level 2, Von House, Remarkables Park
Ph +64 3 442 3101 ? Fax +64 3 442 3102 ? Mob +64 274 566 660
Email justinr@aireys.co.nz ? Web www.aireys.co.nz
The information contained in this email is privileged and confidential and intended for the addressee only. If you are not the intended recipient, you are asked to respect that confidentiality and not disclose, copy or make use of its contents. AIREY CONSULTANTS LIMITED ACCEPTS NO RESPONSIBILITY FOR CHANGES MADE TO THIS EMAIL OR ANY ATTACHMENTS AFTER TRANSMISSION FROM AIREY CONSULTANTS LTD. If received in error you are asked to destroy the email and contact the sender immediately.
P Please consider the environment before printing this email.
Regards
Justin Ralston
neilyj666
You ideally need the finished surface pasted into an egl in Civil before IMXing out as cut will never show up in IW as the highest surface is always visible.
Copy the EGL, use the design surface as a Hide Boundary and then paste in the design, then only load this surface from the IMX.
You could also try changing the display order of terrain surfaces in IW.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
