non linear projects in Infraworks
neilyj666
Mentor Mentor
Message 1 of 30
neilyj666
I quite like the 3d orbit speed in infraworks so want to use it for visualization. I have an existing ground level dtm with an aerial image draped over which looks great. I have brought in earthworks platforms that have been designed in civil 3d but they take the aerial photo texture and so can't be seen easily.
is it even possible to do this - I have seen a Youtube video showing a dam in China that shows exactly the sort of thing I want to achieve but I have no idea how to do it - any clues gratefully received...:)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (29)
Message 21 of 30
neilyj666
Tim
I'm determined to crack this one......
When exporting the 3D polyline surface boundaries using MAPEXPORT, do I need to change the Geometry to anything in particular?
2013-09-10 09_50_39-AutoCAD Civil 3D 2014 - [Context Cranepads.dwg [Civil]].jpg
Message 22 of 30
neilyj666
So close and yet so far.....
Message 23 of 30
tcorey
On the Options tab of the MapExport dialog, be sure to select Treat closed polylines as polygons and when you configure the data source in InfraWorks, but sure to set Convert Closed Polylines to Polygons, on the Source tab.
Your image looks pretty good to me. What's missing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 24 of 30
neilyj666
Thanks - just about to try this at home; hoping my laptop won't explode running Infraworks...!!!!
There is a linear feature running up though the middle (a stone wall) and the hardstands can be made out in the background and foreground but they are draped with the EGL and so aren't easily visible unless viewed against a skyline
Message 25 of 30
neilyj666
Making some progress - I can now see the hardstands and have given them a green theme but it is still possible to see the underlying aerial photo; should I give them a texture in Civil 3D before IMXing them out?
Message 26 of 30
neilyj666
Cracked it...made a coverage theme and dragged and dropped to the model (thanks to Dana Probert for the pointer http://bimontherocks.typepad.com/my_weblog/2012/10/importing-parcels-with-black-outlines-in-autodesk...
Message 27 of 30
Todd_Rogers
There is a new feature in R2 that will allow you to do this with a coverage area.  Works pretty good.
Todd Rogers
Civil Administration
Message 28 of 30
neilyj666
so you don't need to do the SDF coverage method?
Message 29 of 30
Todd_Rogers
Here you go...
Todd Rogers
Message 30 of 30
neilyj666
Not sure that that method would work for my particular project
