Create multiple buildings
richie_hodgson
richie_hodgson
I have an shp file with multiple building footprints, It looks like I can import those with a wall height and roof, are the buildings then individually editable, I.e. add different wall textures, change wall heights, change roof slopes.
Richie
Alfred.NESWADBA
yes, you can. Select the object, right click ==> properties, change the properties you like and ==> refresh (button on top of the property-palette) refresh.
If you want to see the changes while editing the values without manually update it activate the checkbox left to the button.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
