Model Builder Request Failed. Problem 210, Model Builder Not Working!
hydroplan
Message 1 of 32
hydroplan
Hello There, Absolute beginner with infraworks here so be patient.
I'm attempting to use model builder for a select area that comes under the 200 sq.km limit. However when i select create model, i get the error code 210. I've looked at several forums and attempted to find a solution myself. However to no avail. I'm just looking for some advice or a solution to this problem,
Many thanks,
Rob
Replies (31)
Message 2 of 32
SethHall
Hi @hydroplan
What version are you seeing this issue on? Are you on a trial of InfraWorks?
Seth Hall
Product Owner
Model Builder
Message 3 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hydroplan
in addition to @SethHall 's question, can you send the InfraWorks log files from C:\Users\<<USER>>\AppData\Roaming\Autodesk\Autodesk InfraWorks\logs ?
Karsten
Karsten Saenger
Message 4 of 32
hydroplan
Hi  @SethHall,
yes I'm currently using the trial version of infraworks 2019 to learn with, before using the full version.
regards.
Message 5 of 32
hydroplan
I'm having trouble locating the Logs following - C:\Users\<<USER>>\AppData\Roaming\Autodesk\Autodesk InfraWorks\logs
the closest I can get is - C:\Program Files\Autodesk\InfraWorks
any advice on where I can find the logs?
Many thanks,
Message 6 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hydroplan
probably the folder is hidden. Type "%appdata%" in the Windows File Explorer to open the hidden folder path.
You can select to have the file Explorer always show hidden files in the file explorer options / settings.
Karsten.
Karsten Saenger
Message 7 of 32
SethHall
Hi @hydroplan
So is Model Builder working for you at this point in time? If not, I have some additional questions/suggestions:
Do you or your company have a BIM360 account? If so click the "B" in the upper left of the InfraWorks window and log into BIM360 when the browser launches.
Have you ever installed an earlier version of InfraWorks on this machine you are working on right now?
Seth Hall
Product Owner
Model Builder
Message 8 of 32
hydroplan
@SethHall,
It currently still isn't working, we don't have a BIM360 account and we have never had a previous version of infraworks installed.
when using my autodesk log in to get into BIM360, several packages and options are offered to me, which one do I need, if any?
Many thanks.
Message 9 of 32
hydroplan
@Anonymous.Saeng
I was able to find the logs using the way you'd suggested, I have attached three logs which I hope will be of use.
many thanks
Message 10 of 32
SethHall
Hi @hydroplan
You don't need any versions of BIM360, I was just curious as the entitlements may have played a factor in the issue you are seeing. Could you please browse to this location and delete the following folders:
C:\Users\<<YOUR USER NAME>>\AppData\Local\Autodesk\Autodesk InfraWorks\cache
C:\Users\<<YOUR USER NAME>>\AppData\Local\Autodesk\Autodesk InfraWorks\QtWebEngine
AppData is a hidden folder so you can reveal it by clicking the VIEW tab of Windows Explorer, then check HIDDEN ITEMS to show the hidden folders. Also you can type %APPDATA% in the Windows Start menu search bar.
Close and reopen InfraWorks and those folders will be recreated. Try opening Model Builder at that time.
Let me know how it goes. Thanks!
Seth Hall
Product Owner
Model Builder
Message 11 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hydroplan
I see two types of errors in the log files:
  • connection errors: are you using a proxy server or is any AntiVirus program blocking something?
  • GIT errors: do you have a second GIT installation or a program installed that has its own GIT?
Karsten.
Karsten Saenger
Message 12 of 32
hydroplan
@SethHall,
Thanks for the tips, after carrying out the steps twice, I am still currently getting the error message.
Model builder is opening fine on its own, it's just when I search a specific area and try to create the model of the area, the error code 210 pops up.
many thanks,
Message 13 of 32
SethHall
@hydroplan
Thanks for trying that out. I need to discuss this with my extended team. Please expect to hear from me no later than tomorrow afternoon with an update. Thanks again!
Seth Hall
Product Owner
Model Builder
Message 14 of 32
SethHall
Hi @hydroplan
I have one more request to help us better understand. Could you please launch InfraWorks, then open Model Builder and take a screen shot of the entire Model Builder window?
Thanks so much!
Seth Hall
Product Owner
Model Builder
Message 15 of 32
JohnDutz
I'm having the same problem in InfraWorks 2019.
Message 16 of 32
SethHall
Hi @JohnDutz
Thanks for reporting and providing a screen shot, it is very helpful. We are working on it, and I will update no later than tomorrow. Thanks again!
Seth Hall
Product Owner
Model Builder
Message 17 of 32
EllenYuan
Hi @JohnDutz
The issue should have been resolved , could you give a try and let us know the result? Thanks a lot.
Best Regards,
Ellen
Message 18 of 32
hydroplan
@EllenYuan @SethHall @Karsten.Saenger
Mine is all working fine now,
many thanks.
Message 19 of 32
JohnDutz
Seems to be working now, thanks.
Message 20 of 32
brian.babu
Hi @SethHall @Karsten.Saenger
Log Entry:
2020-08-19T18:31:54Z [15700]: d:\iwdrprod\git_source\desktop\source\alx\servicefoundation\serviceexception.cpp(55): error:
Service Exception: Network issues are preventing this operation. Try again later.
File Name: d:\iwdrprod\git_source\desktop\source\alx\servicefoundation\httpoperationbase.cpp
Line Number: 401
2020-08-19T18:31:54Z [15700]: d:\iwdrprod\git_source\desktop\source\plugins\dataservice\dataserviceplugin.cpp(255): error: Failed retrieving Bing key: Network issues are preventing this operation. Try again later.
2020-08-19T18:32:04Z [15700]: https://code.jquery.com/jquery-3.2.1.min.js(4😞 warn: [QT: js] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
2020-08-19T18:32:06Z [15700]: https://code.jquery.com/jquery-3.2.1.min.js(1😞 error: [QT: js] Uncaught SyntaxError: Unexpected token <
